06 electra glide classic electronics
Old Jul 26, 2011 | 08:40 PM
jwillie's Avatar
jwillie
2nd Gear
Default 06 electra glide classic electronics
just "inherited" an 06 electra glide classic from my exfather inlaw. it runs great but none of the gauges, lights, or radio work. anyone know where i should start? i've worked on other bikes but this is my first harley.
Old Jul 26, 2011 | 10:33 PM
Navyrep1's Avatar
Navyrep1
If everthing else runs/works fine it's probably just a blown fuse. Pull your side covers and take a look. All the fuses are real easy to get to. If not blow, just give them all a wiggle to reseat then try again. If it is blow, then the question becomes, what caused it to blow...trace the wires looking for a pinch or chaffing short. Odds are that it's something simple.
Old Jul 27, 2011 | 09:47 AM
Dallas 13's Avatar
Dallas 13
The fuses are behind the left side cover - remove the left bag to get to them. There is a fuse that runs the guages, etc. Mine blew when I got rain in the cig lighter. This one won't keep it from running. Jwillie - I'm in Fredericksburg, VA. If you have too much of a rough time with it, we can meet somewhere on it.
Old Jul 27, 2011 | 01:54 PM
jwillie's Avatar
jwillie
2nd Gear
thanks guys. going to pull the bag and covers. and check out the fuses. hopefully i can track this down quick want to ride this thing!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 28, 2011 | 02:00 PM
jwillie's Avatar
jwillie
2nd Gear
still blowing fuses, traced the wires to a mouse nest and foud several chewed wires.
not going to be fun.
Old Oct 16, 2011 | 12:54 PM
jwillie's Avatar
jwillie
2nd Gear
thanks for the advice. i just got home from LA and \have time to work on the wiring but i need a wiring diagram thought i had it fixed but when you hit the starter it blows the fuse again. at a loss now. have the bags and seat off and still cannot find anymore wires rubbing. any ideas?
Old Oct 17, 2011 | 12:44 PM
Dallas 13's Avatar
Dallas 13
Have you checked inside the front fairing? Also a good place for mice.
Old Oct 18, 2011 | 10:31 AM
jwillie's Avatar
jwillie
2nd Gear
yeah took the fairing off and it was a mess the previous owner had left wires lose and there were a few pinched. i straightend everything out rewraped the wires and zip tied it all back up. since it was blowing the fuses only when starting i also removed and cleaned the contacts on the voltage regulator. took it for a ride yesterday maybe 20 miles and the gauges were still working.
the-pun
Audio Systems
May 24, 2016 03:35 PM
sportynightster
Motorcycles For Sale
Sep 27, 2015 01:34 AM
canyon-electra
Sep 13, 2014 04:15 AM
Tommy 33
General Topics/Tech Tips
Sep 28, 2008 01:45 PM
bigjohn8302
Nov 1, 2005 02:46 PM
