Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
On that 30.5 are you talking 30.5 mili volts? Because I am trying to figure out how a system that only has a 12 volt battery, on a bike that just has the ignition switch turned on and nothing running, can produce over 12 volt anywhere in the system. (i.e. like you say 30.5 volts?).
Ok, I'll check all those spots tonight when I get home.
Regarding the 30.5 volts....I was thinking the same thing about how that can't be possible so after reading your post, I checked it this morning again before I left for work. And sure enough, in the right hand side of the multimeter screen it lights up "MV" on the 30.5 right side and just V on the 12.05 left side.
I never even knew there were millivolts.
Does that change anything....its probably still the problem area...right?
Before i do anything...should I clear the codes that I checked earlier? Any advantage/disadvantage?
Let's hope I find something tonight!!!!
sv
I knew it was MV and not V......only thing it could be LOL
Asked for some help on this on another forum and was suggested that the 30.5 mv is just induced due to the type of multimeter and that in fact the wire has no voltage.
You might need to follow that wire back to the next connector and test there as well.
Did all the Molex connectors go back together easy ? You did not have to force them in even slightly ?
You are 100% certain that all the wire colors match from the male to female connectors?
Some wires look very similar and a bright light shows they are different.
I'll retest all these things again tonight. but as of now...
- Yes brake lights and horn works.
- Molex connector went back together really easy, i just popped that white housing off, tested for voltage and slide it right back on.
- yes 100% sure but will look again.
I'll try to track that bundle of wires back....do you know where the next connector would be? I guess I can look at my manual and see if i can find anything there.
Now I need to ask this question.........The front brake switch that makes the brake light work gets it power from the orange/white wire that your now testing and shows no power.
So how is it possible that the brake light is working from the front lever?
Got me??? That's why I'm on here.
Went out to make sure that was still the case....yes. No blinkers, but i can get the brake light to work. Now, FWIW, the brake lever isn't on the bike as I have the handles off right now, but when I turn on ignition the brake light come come on right away...I can push the little release button on the switches to imitate the brake being depressed. Bottom line the brake lights work with the front lever.
Also, just reset all the codes to see if they'd come back. Yep...b1121, b1122
Then the wire must have power..........where are you putting the probe for ground ?
ok, i'm going to earn some dumbass points here. I was testing the wrong wire on the 30.5MV....the orange/white tests out at 11.95....sorry about that....the pink one looked pretty close. my bad.
so along those lines i did verify that i've got all of the colors lined up and matching.
so, what we know...there is power coming to the point where it connects to the controls, but no blinking.
sorry for f'n that up.
steve
Edit - tested the blue wire ine each connector that goes out to each blinker. They both have 11.95 V on them.
