Lights don't work, start button doesn't work.
I don't know where anything would be pinched....ughhhhh!!!
Let's see if we can get this solved in under 100 posts
Pinched wires on anything you took apart and put back together as I am not there and can't see what you have done.
I once spent 2 hours chasing a problem on a 03 Dyna that the owner had put new bars on and could not find the problem when finally the owner told me just in talking how he had put a new taillight on at the same time and yes the pinched wire was back there not in the bars. He could not see how the problem was back there do did not bother telling me!
Let me know.........
tested each contact in each blinker on both continuity mode and Ohms mode. Tested them all with the lighting relay and and once with the lighting relay out. Figured I'd just try to get as much data as possible. Each contact ended up testing pretty much the same each way:
With relay taken out
Back Right: no continuity, 7.27 ohms
Back Left: no continuity, 7.27 ohms
Front Right: no continuity/7.27 ohms on one, continuity/1.5 ohms on the other.
Front Left: no continuity/7.24 ohms on one, continuity/1.5 ohms on the other.
With relay put back in:
Back Right: no continuity, 7.21 ohms
Back Left: no continuity, 7.21 ohms
Front Right: no continuity/7.22 ohms on one, continuity/1.5 ohms on the other.
Front Left: no continuity/7.27 ohms on one, continuity/1.5 ohms on the other.
For good measure and whatever its worth, i also picked up new bulbs all around today and put them in after the test to see if that would magically solve the problem. No such luck.
I'm trying to eliminate in my (novice)mind what it could be...
crossed wires - no, because i had them blinking for a few seconds before the short blew it.
no power - no, i tested (i believe correctly) to see if i was getting voltage to the contacts.
both switches bad - no, i tested for continuity and it was there when the turn signal buttons were pressed.
TSM bad - ?? not sure but a guy at the shop (looked like he knew what he was talking about) said very rare that they go bad and no way to test them..??
seriously....thanks again for taking the time to help me out with this...I'm sure you wish you never jumped in on it
steve
Did you check accessories fuse ?
Don't forget you can use you multimeter to check a fuse as sometimes they look good and they are bad.
If the TSM is bad the part number 68920-07 and is used in Sporters and Touring bikes RRP $114
Ebay $40 buy it now with $10 shipping
http://www.ebay.com/itm/Harley-Blink...de61d5&vxp=mtr
tested the orange/white wire at the connector that connects to the signals. left side tested at 12.09, right side was all over the board always seeming to settle at 29, but would drop down to 4 and 0...not sure if that was just the connection i had or if its a problem. this was all done with ignition on. ignition off showed nothing (as I would expect).
Check the wire carefully and make sure it matches up at the plug with the correct color
This has got to be something.....right????
