Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I'll have to see if I can find a photo a or see if I have a old blinker here.
When you pry the rubber out to remove the blinker inside the sleeve behind the globe where the wire(s) runs up the middle is a little spring that give the globe some pressure.
Well those wires can get hooked up on the spring and that is power to earth and bang goes a fuse.
When you put the blinkers back together I put the globe in then push the reflector part back in............if you pushed the reflector part back in then put a globe in you probably caught the spring.
If you pull one apart and push the center wires up through where the globe comes in you will see the spring and it will make sense what I am saying
Ok, i know that spring...I was confused by calling a something a circuit board. I would not be surprised if that is happening...as it doesn't seem like the wires are held very tight in that white housing/circuit board? So maybe i'm doing something wrong as far as holding them in place. Picture attached of the blinker.
Ok I called it a circuit board because it holds the postive power posts in place and with the globe pressed down on them and pressure from the spring they get held in place.
Pop them out and check none are caught on the spring then pull the wiring back down as you push the bulb in so you know it is straight and then slide it back in the housing.
Or for testing purposes you can leave them out of the housing and check that none of the center contacts are grounded
Well, that spring on the right side must be the culprit...at least for some of it. Got both lights hooked up, right side w/o the spring and both turn on with ignition. Good news.
Bad news, still getting nothing when I hit either right or left blinker buttons. Nothing in front oe rear and indicator on dash doesn't light up.
Going to check fuses now for what that'll be worth......
What about holding both blinker buttons in together to see if the 4 way flashers work and at least go back to the flow chart and start from beginning again now that you have fixed part of the system.
I feel I'm getting to the end of the line here without a favorable outcome....
Held both blinkers. Nothing.
Went back to flowchart.
- yes. Turn signal lamps on continuously. (the way I read it, the answer is yes anyway)
- no. I checked terminal 5 & 6 on the connector to the TSM with red on the terminal and black on 12. Also checked with black on neg battery terminal.
- answer....replace TSM
Questions...could the TSM have "blown" or something....what does this thing do? It seems like just an empty plastic tube.
I guess I just get a new one and see if it does something......
Well I did say it was hard to do electrical faults over the net.
When it says are turn signal lamps on it does not mean the marker light side.
So if you have dual filament globes at the front and single filament globes at the rear it wants to know if the turn signal filament is working not the marker filament.
