Fuel or electrical problem help plz..!
Old Nov 23, 2012 | 08:31 AM
Mr. Wizard's Avatar
Mr. Wizard
Originally Posted by deergutz1
Not sure what the fuse that was blown protects it was under the right side cover next to the ecm only 2 fuses in that block.? what is happening is the fuel system was intermittently coming on and off and now nothing and no red engine light when you turn on the ignition or on off switch.
Check under the left side cover for your main fuse panel. Pull every fuse one at a time. Inspect each fuse. Use a meter, don't trust your eyes. Clean all the contacts on each fuse with a light sanding. Inspect each socket for corrosion. Do this especially on the 40 amp master fuse.
I've seen similar issues like this and it was a loose master fuse. It gave just enough power, sometimes, just to power everything but not consistently.
That would be my first step.
Hawk66
Apr 25, 2019 05:09 PM
mr396
Aug 12, 2013 06:37 PM
arthur6
Sep 27, 2009 03:09 AM
04rdkng
Jun 28, 2009 04:49 PM
Naz_Man
Aug 2, 2007 08:31 AM
