electric fuel pump
Old Feb 1, 2014 | 01:12 PM
bdrf's Avatar
bdrf
Default electric fuel pump
I have a 2007 FI Roadking . Are the electric fuel pumps a well-known problem ?
Old Feb 1, 2014 | 01:31 PM
nevil's Avatar
nevil
Welcome.
Electric fuel pumps can be a problem like anything else mechanical on the bike, but I don't think it's that common. What seems to be more common are pinholes in the fuel lines inside the tank. Usually from the line rubbing the tank wall. There's also a filter in the tank, you didn't say how many miles you have but it's something else to check.
Why do you ask?
Old Feb 2, 2014 | 04:24 AM
bdrf's Avatar
bdrf
I have like 48.000 mls . When I open my throttle fast de engine drop dead . Then I have to switch off my contact , back on and wait until the fuel pump stops pumping before the bike will restart
Old Feb 2, 2014 | 05:07 AM
Stiggy's Avatar
Stiggy
How long does the fuel pump run before it stops pumping?
Old Feb 2, 2014 | 05:18 AM
Campy Roadie's Avatar
Campy Roadie
The first thing I'd do is fill the fuel tank all the way, take a ride and see if that fixes it. If it does, you have hole in the plastic line inside the tank. Fairly easy fix.
The second thing I'd look at was the fuel filter. WOT fuel starvation can be a sign of dirty/clogged filter that doesn't flow enough fuel. Easy fix with Youtube and some tools.
If those two things didn't work, I'd look at the pump. But start with the easy, basic and cheap stuff first.
Old Feb 2, 2014 | 06:56 AM
bdrf's Avatar
bdrf
I think I do that , thanks for the advice , the pump runs a few seconds
Old Feb 2, 2014 | 07:01 AM
bdrf's Avatar
bdrf
Is there something like a MAP , MAS sensor or an Intake air controle valve on this bike ? because maybe something like this could cause the problem also I believe
Old Feb 3, 2014 | 12:30 PM
bdrf's Avatar
bdrf
Question
nobody ??
bdrf
Feb 1, 2014 09:38 AM
Potato_Potato
Apr 26, 2013 11:51 PM
CoyoteQuick
Jan 17, 2011 05:49 PM
Bobbed Out
Feb 3, 2010 08:07 PM
Tanker2
Feb 12, 2009 02:29 PM
