Electrical problem
Old Apr 8, 2007 | 07:03 PM
M1Tanker's Avatar
M1Tanker
4th Gear
Default Electrical problem
I was working on the ignition on my 2005 Screamin' Eagle, and now neither of my brake lights, my signals (and 4-way flashers), and my horn don't work. Also, the tachometer doesn't work and the tripometer doesn't display, unless I push the button on the back of the instrument cluster.
When I press the "Run" button, the fan sometimes initially comes on for a few seconds. Also, the little red key light on the lower instrument panel will turn on for a few seconds, then turn off, only to turn on and stay on just a few seconds later. The bike starts fine, but the previously-mentioned problems remain. Any help help would be much appreciated.
Old Apr 9, 2007 | 06:04 PM
glide's Avatar
glide
Default RE: Electrical problem
Check the fuses? The red light means you have a code stored, pull the code out to see what it is and it will give you a direction to look.
Here's the process to do it https://www.hdforums.com/m_43975/tm.htm
Old Apr 10, 2007 | 12:33 AM
M1Tanker's Avatar
M1Tanker
4th Gear
Glide,
Thanks. It was a short with one of the the ignition wires.
NorthDakotaSoftail
Aug 7, 2019 04:29 PM
tloc1000
Jul 4, 2017 10:48 PM
RickRock
Mar 10, 2015 10:21 PM
rhythm1978
Feb 5, 2014 09:45 AM
rkbikeman
Oct 31, 2008 09:24 PM
