Ironhead A place to talk about Ironheads.
Backfiring 84
Old Jul 25, 2007 | 12:05 AM
sepixlh's Avatar
sepixlh
Default RE: Backfiring 84
Yep brace went to airbox from front cylinder intake tappet mounting bolt....in old scoot, but if I remember correct from -79 ( or someting like that) bracket is mounted to cylinderheads like THIS
Old Jul 25, 2007 | 12:51 AM
wreck74's Avatar
wreck74
put a brace from where the carb bolts to the manafold to the top center case bolt. if you don't have a brace holding the carb and manafold you'll have nothing but intake leaks.
Old Jul 25, 2007 | 08:11 AM
83XLX's Avatar
83XLX
ORIGINAL: sepixlh
That's a little more elaborate brace than they had. A simple strap from the back of the air cleaner to a tappet bolt is what mine had stock. There's also a couple of bosses on the heads that some air cleaners bolted brackets to.
If the gas cap vent is clogged (even partially), you'll get fuel flow until a vacuum is created, such as higher speed running. It may flow enough at lower speeds to not be a problem, and fuel flow may "catch up" when you slow down for a couple of miles after an episode. Try the cap thing next time it happens. If it starts running right in a few seconds, that's the problem. If not, well, at least you checked.
Here's my air cleaner brace - it came with a round air cleaner kit, but I adapted it to my SE air cleaner back plate. It bolts to two tappet bolts and is pretty strong.
[IMG]local://upfiles/21410/9B893F530276442AA2F94FDCB482A4B7.jpg[/IMG]
Old Jul 25, 2007 | 06:50 PM
wfo's Avatar
wfo
ORIGINAL: 83XLX
ORIGINAL: sepixlh
the mount for the brace is on the bottom near one of the push rods. Stud sticks up. Aftermarket filter has no where to mount, but i think i can fab up something and self tapper screw it into the bottom of the filter.
Will definately try the gas cap next time she acts up. Which hopefully she won't.
I also added a couple bolts in the holes at the end of the pipes. Was told I might need that little bit of back pressure.
My *** is too whooped to wrench tonight though.
[IMG]local://upfiles/36942/504BABECA7DE45A1839C112A20DB75C3.jpg[/IMG]
Old Aug 19, 2007 | 06:58 AM
wfo's Avatar
wfo
little update.. been busy as hell, and haven't even gotten to ride the bike much. But I did manage to fab an air cleaner support bracket out of some flat stock aluminum I found at the hardware store. Only put on about 40 miles since then, but i can report no backfiring problem on that little ride. [sm=icon_cheers.gif]
Mr1986FLST
EVO
58
Feb 1, 2021 09:25 AM
j440
EVO
18
May 24, 2015 05:25 AM
RATROD HOG
May 22, 2007 12:58 AM
ngf74
Ironhead
Oct 21, 2006 06:59 PM
PJsthnam
Shovelhead
Mar 29, 2006 02:55 AM
