Ironhead A place to talk about Ironheads.
the speedometer headache
Old Aug 20, 2007 | 05:02 PM
shotpeen28's Avatar
shotpeen28
1st Gear
Default the speedometer headache
(in case you missed this query before) From shotpeen28--67 XLH Here's what I got. There's no place on the underside of gearcase to attach a speedo drive cable. (Maybe bike didn't come w/ a speedo. ; maybe cases aren't orig. Dunno) Ive read it was a flawed thing anyway, prone to failure. Later models had speedo cable driven by a front wheel geared mechanism and i'm told it only fits up w/newer front ends w/ disc brakes. Iv'e got a cool, orig. speedo/tach. item for my restoration & need a drive device. Ive read about a rear wheel cable drive for much later models. Any ideas? I'd hate to go w/aftermarket elec. stuff. Shout back Thanks MF
Old Aug 20, 2007 | 06:52 PM
piniongear's Avatar
piniongear
Default RE: the speedometer headache
The speedo drive goes into the transmission on the right side just behind the oil pump. I have highlighted this on the illustration. The drive is not shown, just the threaded hole where it screws into the case.
Someone may have removed yours at one time, but there should be a plug in the hole.........pg
[IMG]local://upfiles/8331/BD7B6FD430774693BE43B21AA7476AC6.jpg[/IMG]
Old Aug 20, 2007 | 08:05 PM
shotpeen28's Avatar
shotpeen28
1st Gear
Thanks pg, (and that's a mighty fine looking ride you have there!) MF
Old Aug 20, 2007 | 11:58 PM
sepixlh's Avatar
sepixlh
Some cases speedogear is removed be cause of damage, I have seen many biker have replced
original speedo with bicycle speedo. Problem with those are that wires are too short for IH.
There is also wireless options but usually ignition interferes it so that is shows "whatever"
I have used Sigma 800 in some cases where that speedogear hole is welded ...
Old Aug 24, 2007 | 03:11 PM
Oldtimer of NM's Avatar
Oldtimer of NM
Any chance you have a later model crankcase? In the 70's, they moved the speedometer drive to the front wheel and stopped drilling the case for it.
Old Aug 26, 2007 | 11:09 PM
mk2007's Avatar
mk2007
I also have the speedo drive with the unit in place. The previous ownerinstalleda plastic-cup over the part that is on the outside. The thing is that it leaks oil (Primary oil). Not so much but it leavs a mark on the garagefloor after each ride. My question is about getting a new/old speedo to my XLCH '71. I also have a front wheel speedo option. Which would be best to use in terms of cabling and lasting the Trans speedo drive or the Front wheel option?
johnod
EVO
19
Feb 5, 2020 11:19 AM
Beemervet
EVO
Aug 5, 2017 06:57 PM
jrsmith313
General Topics/Tech Tips
May 7, 2017 09:07 AM
1sandking1
EVO
18
Aug 9, 2012 10:03 AM
Blown 331
EVO
May 23, 2008 10:46 AM
