Flywheels aren't S&S. Markings on the side is "exl 4 5/8 1400"
center reads truett osborne wichita kansas.
Pistons are s&s 92-3702f forged piston assembly for use with 4 5/8 stroke in 1972 -1985 sportsters.
Jugs have a /, triangle and an F marking, I assume that the company's initials are AF
ok! now,did the cylinders come from the kit also? if so,Ya got it made..only thing left will be machining cases, and balancing,maybe head work. If not,just make a stroker only..using standard cylinders/rods.
then,maybe a set of wheelie bars! keeping that front wheel on the pavement might be a bit tough..i bet Gunnuts droolin!
OK, here is some "very old information" back in the days of bored/stroked Sportsters (about "70" ish), Stock HD rods were considered to be strong enough for even Fuel drag Bikes (40% mix). We did polish the sides of the rods to reduce stress risers and liquid penetrant inspect them for cracks.Saw some failures but not because of rods! By the way, about this time you could get a set of 5 inch stroke flywheels from S&S. Also, it is very complicated job to get rod clearance in the cases (NOT), you use a hacksaw! By about "72-73" the fuel guys were taking "883" inch motors to 110 Cu. In. by weld building up the top of the cases and boring them for even bigger cylinders!
If you are building pure RACE bike you can use those cams, otherwise I personally recom factory P-cams or PB+ cams...much more nice to drive chopper when you have torque in lower end.
For some good info on Truett an Osbornne flywheels and strokers an what is needed look up victorylibrary.com Mr. Diamond is very knowledgeable on the subject. Also tells whats needed for eack flywheel kit
