Ironhead A place to talk about Ironheads.
Cams question
Old Feb 13, 2010 | 12:38 PM
  #41
EvilWayz's Avatar
EvilWayz
Originally Posted by GA Ironhead
EvilWayz,
Which Sifton grind are they? New or vintage?
Edit: The grind and specs should be stamped on the cam gear surface. They sound like Titans (Minus Minus). Intake lift is different however.
http://victorylibrary.com/tech/XLcam-c.htm
They are vintage, and they must be titans because they are stamped minus minus.
Old Feb 15, 2010 | 11:00 AM
  #42
gunnut1's Avatar
gunnut1
Back in their day(late 60s-early 70s), Sifton Minus-Minus was the answer for everthing for drag racing with bigger inch engines and higher compression (11-12 to one), they were used with gas and fuel ( that is what we had in our fuel drag 77 incher) never saw any in smaller gas engines, I was told to use the PBs in my 11 to 1 street motor (77 cu in) I did and I was delighted with it (once I got it STARTED !). I was told that you lost a lot of low end with the Siftons. Could not tell that with the high gear only fueler.
Old Feb 18, 2010 | 05:21 AM
  #43
GA Ironhead's Avatar
GA Ironhead
Here's what the 1981 Sifton catalog said about minus minus cams.
Old Feb 18, 2010 | 08:06 AM
  #44
IronMick's Avatar
IronMick
The complete 1981 Sifton catalog plus two other historical Sifton files plus some other interesting stuff is here on my SkyDrive site ...
http://cid-e2880b68d32bbca8.skydrive...e.aspx/.Public
BB61Bagger
Mar 24, 2013 09:11 AM
MichiganRider
Mar 7, 2012 08:45 AM
6 gun
Exhaust System Topics
Aug 31, 2009 04:48 PM
rok312
Aug 14, 2008 10:10 PM
Meathooks
Jan 23, 2006 07:53 AM
