Ironhead A place to talk about Ironheads.
Mertle Update
Old Jul 21, 2011 | 09:11 PM
  #31
IronMick's Avatar
IronMick
Note this change on my brake side. You might consider this for your shift side. With this mod i need move my foot a much smaller distance to apply the brake.
The lever has to move only about 1" now rather than about 2" in the original lower hole. This means that at the other end my foot moves only about half the previous distance.
Old Jul 21, 2011 | 09:13 PM
  #32
IronMick's Avatar
IronMick
Old Jul 21, 2011 | 09:32 PM
  #33
OlGrampy's Avatar
OlGrampy
When I saw the hole drilled in your brake lever, I thought this may be a solution for my shifter. Yea, those set screws are not good. I am going to drill and tap that, and I think another half inch of travel on the shifter will fix it. The PO drilled a hole in the shaft that i tapped, resulting in that a little off 90 podition....this may be the answer to my problem.
DYNAMITE 1
Jul 18, 2009 07:33 PM
JRK5892
Feb 8, 2008 03:04 AM
revolution
Nov 13, 2007 07:57 PM
ChromeJunkie
Aug 13, 2007 12:25 PM
