Ironhead A place to talk about Ironheads.
Ironhead rear motor mount stud
Old Apr 20, 2011 | 05:58 PM
piniongear's Avatar
piniongear
Well, I agree with you on what you say. Since you are an engineer you should understand the reasons for using a stud over a bolt in this application.
As far as discussing with members of the design team you would have to return to the beginning in 1952 with the first K Model.
These guys are long, long dead for the most part.
Any still alive would have been unemployed for decades by this time.
pg
Old Apr 20, 2011 | 06:40 PM
Ironhead Ed's Avatar
Ironhead Ed
HAHAHA this is very true about were they would be now pg! I'm just happy the old boys gave us the Ironhead to have fun with. It would be so exciting to relive the birth of the Ironhead.
Old Nov 7, 2024 | 07:54 PM
Odin129's Avatar
Odin129
Stage I
Originally Posted by Ironhead Ed
Hey everyone this is my first of many posts on here so bare with me if I am a little short. I'm rebuilding my 1000cc Ironhead and I noticed that my rear motor mount was cracked. I am replacing it when the new one once it gets here. What I can't figure out is if the top stud on the lower T part is screwed into the block or if it is stamped or pressed???? Can anyone help me with this question?
I have an 1983 ironhead I just picked up. I came into the same issue. That motor mount was a stud. I it came out with a little nudge. I feel like it would be better at the bottom hole. For a guidance pin to easy the engine back onto the frame. Just to square things up. That's what I'm going to do. Please say something if this seems like a bad idea or if someone things of a reason I shouldn't do this.
Old Nov 8, 2024 | 10:47 AM
Racepres's Avatar
Racepres
Older Ironheads they were studs..,.we always pulled the studs and used Bolts..
O.E, or Aftermarket Mounts still need "fitted" pattern Blue or Sharpie... and ensure the thing sits Flat on the engine bosses... Yup...File on mount...or thin Steel Spacers even, or...Gonna Break another.. unless your Luck is Much Better than mine..
roundy
May 16, 2019 05:33 PM
tonygret
Nov 10, 2013 06:02 PM
Nor_Cal_Wolf
EVO
Jun 8, 2011 10:40 PM
srurebel55
Dec 15, 2010 07:03 PM
JimboFXD
Ironhead
Sep 22, 2007 02:43 PM
