Ironhead A place to talk about Ironheads.
early 73 or late 73?
Old May 15, 2011 | 09:38 AM
oil leak's Avatar
oil leak
Default early 73 or late 73?
Hey I am wondering if i have a early 73 or a late 73. Im sure its a certain # on the vin but not sure on which one. Any clues would help. Thanks
Old May 15, 2011 | 10:38 AM
IronMick's Avatar
IronMick
I do not know myself. www.sportster.org is traditionally the best source for historical details. Someone else may come along who knows.
Old May 15, 2011 | 12:23 PM
piniongear's Avatar
piniongear
Impossible to tell. There is no difference between early and late in 1973. Why do you care? Just curious?
As for the serial (vin) number......
If the first 2 digits are 3A......... you have an XLH
If those 2 digits are 4A................. you have an XLCH.
The next 5 digits are the numbers as the engine came off the line.
The lower the 5 digits the earlier the engine.
This is the only way to determine if your bike is early or late 1973.
There were 9,875 XLH models made in 1973.
There were 10,825 XLCH models made that same year.
So if your number is 22225 you have an early 1973.
The next letter is 'H' and it stands for the manufacturer (Harley Davidson).
The last digit is the year the engine was made. In your case this should be a 3.
Hope this helps answer your question.
pg
Old May 15, 2011 | 12:29 PM
oil leak's Avatar
oil leak
Thanks Ill have to check it out. Ive Noticed that some of the parts are different between E1973-L1973. Are the Early 1973 pre AMC?
Old May 15, 2011 | 12:40 PM
piniongear's Avatar
piniongear
No.
AMF runs from 1970 to 1984 (approximately)
and the only real difference are an original AMF machine would have the AMF decals on it. Other than that, no difference.
pg
PS: Tell me, which parts are different between an early and late 1973?
Old May 15, 2011 | 12:54 PM
oil leak's Avatar
oil leak
Ive seen cylinder head bolts listed at different lenghts late 73 is 3.5" early 73 is 2.9" but yeah mostly I was just curious.
Old May 15, 2011 | 08:00 PM
Harley Bass's Avatar
Harley Bass
I believe early 73 head bolts have 6 sides and late 73 head bolts have 12 sides. If the bike is all together and stock its an early 73 if it doesn't have blinkers and late 73 if it has blinkers. The tail light is also different from early to late 73.
Mine is an early 73.
Old May 16, 2011 | 12:42 AM
sepixlh's Avatar
sepixlh
Yep, 6 sides vs 12 sides. I think E73 has same cylinders and cylinderheads than -72 witch are not fitting to any other year ( not 100% sure about this).
Old May 16, 2011 | 07:54 PM
oil leak's Avatar
oil leak
Thanks for the Info. Guessing I have a late 73 due to blinkers. Looks like you just pulled off the showroom Harley Bass, nice job!
Old May 17, 2011 | 06:20 AM
Harley Bass
Appreciate it.
