Knuckle Head A place to talk about Knuckle Head motors.
And today the 1941 is starting a build before paint and final
Old Jan 2, 2022 | 02:14 PM
johnjzjz's Avatar
johnjzjz
Default And today the 1941 is starting a build before paint and final
Its an early one of 2600 that the factory had to bend the frames on because of a mistake it was on the assembly line so its repair number is low but it has a late motor / early 41 motor number
Old Jan 2, 2022 | 02:17 PM
johnjzjz's Avatar
johnjzjz
The thing that is not in the parts book is the special spacers they made for them to pick the dsash up so it could be bolted down
you can see the dog leg in the frame
Old Jan 2, 2022 | 02:22 PM
johnjzjz's Avatar
johnjzjz
Old Jan 2, 2022 | 05:16 PM
hellonewman's Avatar
hellonewman
They had to change the neck angle on 2600 or just a handful of the first 2600?
Im assuming the bull neck frame neck forging was a tweak of the existing die for the 18" wheels that they machined offset to get the new angle before the final revised neck die was ready. Interesting details in these old bikes.
Old Jan 2, 2022 | 05:56 PM
johnjzjz's Avatar
johnjzjz
They made a running change to 16 inch wheels for 1941 beginning production - but left the 1940 - 25 degree neck in place built 2600 machines before they realized the police machines that were delivered were going out of control and crashing because of the negative trail
they stopped production some 25 or so bikes had already crashed - then decided to bend the neck angle to 28 degrees on all remaining and any machines they could get returned to the factory to repair them
its an odd duck but its lol history
Old Jan 3, 2022 | 09:39 AM
Architect's Avatar
Architect
You have two of your bikes on the racks, I need to make a trip to your place later this winter to check on your progress.
Maybe help you with the nice bottle of Gentleman Jack as well.
Good luck with both builds, lock the doors and don't let any customers in the shop!!!!!!
Old Jan 3, 2022 | 02:21 PM
johnjzjz's Avatar
johnjzjz
6 showed up before 10 am today i told them may / June maybe
Old Jan 4, 2022 | 09:16 AM
Architect's Avatar
Architect
June of 2023!?!?!?!?!?! You got bikes to build, you also need to get your rubber Shovel FLT back on the road. Busy, busy John.
Old Jan 4, 2022 | 02:42 PM
johnjzjz's Avatar
johnjzjz
one of my loaner engines came back from hot rod its a peppy piece a stroker evo - i am tempted to throw it in the FLT for fun
Joe12RK
Shovelhead
May 13, 2021 07:16 AM
brad75raiders
EVO
40
Sep 25, 2017 12:34 AM
noaccess4321
Powdercoat & Paint
Aug 10, 2011 10:46 PM
t0mmy91
Mar 3, 2010 09:03 AM
VatoLoco
Oct 9, 2006 08:16 PM
