A couple points.
Always want to do back-to-back-to-back to see if the first test repeats with the stock plugs. To be fair, at a minimum, 3 pulls per test. Toss out the best and the worst of the 3. Use that as the comparator.
Also consider new plugs will always run the engine more efficiently than old plugs so these iridium plugs must be compared to new stock plugs to be fair.
I have never seen hp gains from super duper spark plugs or wires after many years of trials.
Bob
While you are absolutely correct about a motor that is properly tuned, I suspect that some motors that are tuned to run lean might benefit from fancy plugs. After all HD did dual plug the M8s so it looks like they needed a little extra spark.. I'm amazed at how well they run even without a tune. Still, does a dual plugged M8 motor run better with the fancy plugs? My guess would be nope..
Today is the first time I've read this thread....and I am glad I did. I went to look at the '18's this past week-end and I must say they whetted my appetite for a new ride. I have a 2000 Electra Glide I bought from an elderly man with low mileage. Nice running bike but the new ones look so good and what the magazines say, they ride so well! Now I am conflicted. I went from trying to pick out a color to now standing back and saying, whoa, I didn't know they had these issues? I know my TC 88 has tensioner issues but that can be dealt with. With what I am reading about the new motor has me on hold. I did stop by the Honda shop today and the new GW looks really good and all the write ups rave about it. And it no longer looks like a geezer bike. I am big on reliability and next to that is accountablilty of the manufacturer to stand behind any and all issues that may arise with the product. I will test ride a new DCT GW this week and if the performance is anything close to what I read about it may be the next bike because as I said, reliability is number one concern for me....but I'm keeping the Glide because it is fun!
Sign seen on a new M8 motorcycle at dealership:
PROBLEMS? MAN, WE AIN'T GOT NO STINKIN PROBLEMS.
my 17 street glide has 21000 miles on it today. I changed the shocks out for progressive heavy duty air shocks. the adjustment of the stock shock all the way up to carry the 400lb load tweaks the swing arm enough that it wore the left side of the rear tire. looking at the tire, you can see the wear path has moved to the center, much better ride now and honestly, this was my only complaint about the new bike.
I change all three holes fluid at 3k intervals, I measure the fluids just to be sure I do not refill more than what came out! that way you never blow a seal. Happy to report, no issues like what is being reported. This month I will change the fork oil. My set up is a stock air cleaner, CVO street mufflers and a se race tuner which I loaded the stage one without modifications to the bike.
If you think the 2000 EG is fun, the M8 is a whole difference experience of fun. But best of luck with the Honda. My M8 is stock, loads of power and has 10,000 trouble free miles.
Why not go test ride a new ultra or whatever. Yes there are some issues. But there were issues with most of the previous engine configs.
Yes you might get more bells and whistles with the GW, but its not a harley...lol JMO
After riding metrics my entire life (none were touring models) I cant say enough good things about my 2017 RKing. The feel is completely different in every way. I'm not talking about seating position or brakes... The motor and its delivery, feel and the fact that its air cooled all combine to create a great overall feel. Metrics feel more like appliances compared to the HD. Not saying their bad, just a total change in riding experience. I never EVER understood the whole Harley thing. Now I do and so glad I made the change.
When you are referring to motors that are tuned to run lean are you referring to Harley engines or engines in general?
I believe Harley went to dual plugs to clean up the last bit of combustion for emissions compliance. Not sure if there is power to be had but simply doing a pull with the plug wires pulled from the outer plugs will answer that.
After many years of tuning these v-twins I have yet to see ANY increase from changing from a new HD plugs to any other aftermarket plug.
Also, until 2017, these engines used an ion-sensing anti-knock system that was based partly on sparkplug, wire, and coil resistance so changing to aftermarket stuff doesnt help the system and will tend to mis-report knock and as a result, timing being retarded up to 8-12degs depending on year/model for no good reason.
Bob
Bob
Engines in general but it might here.. The thing is how are you going to measure it especially on a inertia dyno? Most of the lean run is at partial throttle. WOT on these seem to be tuned for power. Fancy plugs won't likely make any difference there. It will likely take a power measuring brake dyno to see.
I'll agree that the fancy plugs can screw up ion sensing. Also not sure if they help all that much on the M8 dual plug system as the flame front is started from 2 locations. Lean burns, burn slower. 2 plugs speed the combustion process up.. They might help. They night not.
I could see them helping at partial throttle, lean burn, carbed bike or anything that is running lean at partial throttle without ion sensing issues.
