All of this stuff about which exhaust, header or muffler is the best is a long ongoing test of who likes what. If it looks cool some like that. If it sounds cools others like that. Only way to really know is to take same bike under same conditions and keep trying all of them on a dyno.
On a motorcyle like you say when they move the x back 1 or 2 inches is that really enough to make a difference? The real truth is an open free flowing exhaust produces more HP. A restricted exhaust will produce more torque. This is an undisputed fact. With this x in the pipe it will create a more open exhaust with less back pressure. That is for sure.
I built pipes for Harley's, street rods, stock cars and dragters for years in the 70's. A bike i built some for was featured in the first issue of Easy Rider magazine in 71. That started a trend that lasted several years for me. At the time was working at Midas and ended buying my own bending machine and built hundreds of pipes for several years. I learnt a lot from that.We used to put drag pipes on a harley take a crayon draw a line down the pipe. Make a pass down the strip and where the crayon quit melting cut the pipe off. Whether that worked or not don't know but the riders all thought so. Didn't have a dyno back then.
I am not a sales person for any of the makers. But all of us have their own opinions. Some professional and some not. I am not one to judge anyone on that.
One thing i do know is these baggers we are riding today require torque cuz the bike is 900lbs plus two riders and gear. Unless you use the bagger for a bar hopper you'll want the torque higher than the horse. This is why everyone is wanting the cams that produce the higher numbers on the torque curve. They want it sooner and for it to stay longer.
my recent experience taught me that tuning plays a huge role in torque as well..my Street Canons are much less restrictive than the OEM mufflers, and getting a great dyno tune using the SEPST increased torque and moved it lower in the rpm range significantly
You are absolutely correct. Tuning is needed on most all mods and makes all things come together.
I do that on a daily bases here. The dyno sheet I posted shows just that, I am about results in the area most of us run the engine and really don't care a whole lot about 4500 and above as most harley owners never see that area but if your looking for bragging rights that will give you the biggest bang. Average Torque in the RPM area you ride in daily is what I'm after for my bike and that's just what I've gotten. As for your observation of 1 - 2 inches is the difference, it's really 3 -4 on the primary plus the "X" collector about another 6" and the smooth bends with a full size cross over, versus no real collector, a "T" joint along with using the stock squished cross-over. Like I've said all along everyone can run what they want but I know what I've found to work the best in the 2:1:2 market.
I would really like to see a side by side comparison of 3 or 4 of the current top head pipes. Would really like to hear them side by side because that is what I'm really after.
I ordered the MX head pipe a month ago for my 17 CVO Street Glide. I held off installing on the bike until I saw what the 2018 CVO's were as I really wanted a road glide.
I just got my 18 CVO road glide, and in 3 weeks when I get home from work off shore will be installing it.
Several reasons I chose the MX. Most head pipes focus on bragging rights, high rpm HP. I don't ride there much. I tend to keep it under 4K rpm, and am mostly 2500 to 3500. This is where Steve George's Fullsac head pipe shines.
I will be doing a heavy breather fullsac MX head pipe, fullsac 2.25 baffles and a TTS tuner. I am sure it will be great. Power is my goal, not noise.
I have a 138.5 HP and 140 torque CVO road king, it is running a Fullac DX head pipe, 2.25 cores. Torque curve is very long and flat, a lot is due to head pipe design.
