Speed Limiter?
Old Dec 30, 2017 | 08:19 AM
  #31
FLSTFI Dave's Avatar
FLSTFI Dave
Originally Posted by lh4x4
Touring H-Ds have been limited to 116 over the years. Some CVOs at 126(per Cycle World). Don't know about cruisers.
My bikes like the 120R Street Bob are limited to 90 by me.
The 2017' and 2018 are limited. CVO's to 114 mph.
Originally Posted by Peter Quinn
I don't believe there is a limiter.If it does exist, it has to reference off the Speedo
With the Speedo set at 90 mph at an actual 100 mph.
The result was it achieved an actual 115 mph with Stage 111 with the speedo showing 103.5 mph. It made no difference because there is not enough grunt in the engine to push it faster.
What are your before and after figment test speeds on the M8 107" and 114" with Dynojet,limit removed only.
Yea, one of the bigger name tuners out there Confirms there is a speed limiter on the M8 bikes and you don't believe it.
You're choice, but your very wrong. Steve George at Fullsac says there is a limiter, Steve Cole the Designer of the TTS master Tune says there is one.
I watched a 2107 CVO street glide being tuned hit the Rev limiter in 5th and 6th. The limiter was removed with the TTS software before the dyno tune was finished so full runs could be done.
Old Dec 30, 2017 | 09:36 AM
  #32
hollandhunter's Avatar
hollandhunter
I have got my stock M8 107 up to 100mph. That's plenty fast enough for me on a touring bike. An she still had more to give but I backed off.
If I wanted a rocket I sure as heck wouldnt have bought a 700-800lb harle touring bike. With that said again there fast enough for my needs as is.
Old Dec 30, 2017 | 12:35 PM
  #33
Peter Quinn's Avatar
Peter Quinn
Default Speedohealer
[QUOTE=FLSTFI Dave;16951695]The 2017' and 2018 are limited. CVO's to 114 mph.
Well I guess we'll all go ask the guys who sell the limit remover,if there is a limiter?
I believed there was one so I put my money on the Spedohealer which is designed to enable over reading ,Harley speedos to be corrected.It also allows the Speedo reading to be reduced by a percentage. I reduced the reading by 10% So please ask them to explain why the actual top speed was unchanged
I have done the work and the test so unless you can explain the actual result I am calling BS on this!
Old Dec 30, 2017 | 01:59 PM
  #34
Peter Quinn
Default 142 mph
Originally Posted by FLSTFI Dave
The 2017' and 2018 are limited. I watched a 2107 CVO street glide being tuned hit the Rev limiter in 5th and 6th. The limiter was removed with the TTS software before the dyno tune was finished so full runs could be done.
Whilst it is quite usual for the partially informed to confuse the known rev limiter,with the invisible speed limiter subject,you should now enlighten yourself of the difference!
Woha,did you realize you were watching a 142mph Dynojet test? 6th@5500?
Followed by a 5th gear hit on the 5500 rev limiter,running at 129 mph, wow!
Don't understand the need to raise the rev limiter on the test bike or anything but a Stage 111 498 cam or equivalent,which generate maximum HP at 6000 rpm?
Very interested to get the same conversion as the Dynojet Dyno bike.?
Old Dec 30, 2017 | 03:26 PM
  #35
1 2 many's Avatar
1 2 many
Originally Posted by fuelmoto
Speed limiter is removed with Dynojet Power Vision
Thanks Jaime I will be ordering one. I dont hit triple digits all the time but when me and my buddies get together I like to open it up. I plan on buying the 107 outlaw kit and don't want to be limited. I just need to stop riding the S1000rr
Old Dec 30, 2017 | 04:35 PM
  #36
xupd42bmg's Avatar
xupd42bmg
There's damn sure a limiter. I've hit it in 5th. Bike is pulling like a freight train and bam....hits a wall and won't do ****. Would love to know what kind of top speed my bike could achieve but not gonna give up my warranty to find out.
Old Dec 30, 2017 | 05:08 PM
  #37
Steve Cole's Avatar
Steve Cole
HD EFI Guru
MoCo has been installing vehicle speed limiters for a number of years. It is not always the exact same on every model but typically the following holds true.
2014 - 2016 Touring
RPM limiter is 5600 - 5900 RPM
VSS limter is 240 KPH or 149 MPH
2017 - 2018 Touring
VSS limter is 176 KPH or 110 MPH
Some models may be a little faster and some a little slower but this is where most are set by the MoCo.
Old Dec 30, 2017 | 05:27 PM
  #38
MotoJockey's Avatar
MotoJockey
2014 - 2016 Touring
2017 - 2018 Touring
Man, that's quite a drop off in MPH between the 14-16's and the 17-18's. Did the EPA get their nasty little fingers involved in how fast we're allowed to go too? Noise level too high as we scream with glee, lol!
Old Dec 30, 2017 | 05:36 PM
  #39
mjwebb's Avatar
mjwebb
only way my 2015 Road King would do 149 mph is if I pushed it off a cliff
Old Dec 30, 2017 | 06:44 PM
  #40
Steve Cole's Avatar
Steve Cole
HD EFI Guru
No EPA doesn't care about this. It is most likely a tire rating or frame issue for stability at High speeds. One would start by checking the speed rating on the tire they (MoCo) supply as a first step.
