Tune for adding a header?
Old Oct 17, 2017 | 03:42 PM
ChiefT0186's Avatar
ChiefT0186
Default Tune for adding a header?
Hello all,
1st let me say sorry if this has already been covered. I have a 17 street glide special with Screamin Eagle Ventilator air cleaner and V&H Eliminator 400 slip ons WITH a Stage 1 tune. My question is, does it need to be retuned for the V&H Power Duals Head pipe that I am getting ready to put on? Any input welcome and thanks in advance!
Old Oct 17, 2017 | 03:45 PM
Keithhu's Avatar
Keithhu
Yes, it does.
Old Oct 17, 2017 | 03:48 PM
Quik's Avatar
Quik
It will run ok with the current tune but it certainly will not be optimal. When you lose the cat you really need a re tune to provide a little more fuel.
Old Oct 17, 2017 | 04:41 PM
ChiefT0186's Avatar
ChiefT0186
Originally Posted by ChiefT0186
Hello all,
Thank you. You think doing a Smart Tune session with my SE ProStreet Tuner will do it justice?
Old Oct 17, 2017 | 04:44 PM
Steve Helton's Avatar
Steve Helton
Hello all,
If you remove the cat you void the warranty and with oil transfer and other problems think i would wait until warranty was up.
Old Oct 17, 2017 | 04:47 PM
ChiefT0186's Avatar
ChiefT0186
Understandable, but...the transmission oil transfer issue isn't a warranty concern unless it causes a failure. That is something that would be covered under a recall
Old Oct 17, 2017 | 06:44 PM
TomcatCV62's Avatar
TomcatCV62
Um......hmmmm. Well, yes, yes it would.
Old Oct 17, 2017 | 08:07 PM
SWThomas's Avatar
SWThomas
Yeaaaaah.... the trans fluid transfer is definitely a warranty issue.
Old Oct 17, 2017 | 08:33 PM
ChiefT0186's Avatar
ChiefT0186
Okay I wouldn't think the car industry is much different than the motorcycle...but correct me if I am wrong...If there is an issue, that is the direct result of a manufacturing flaw, and they put out a recall for it, then it is NOT a warranty issue and is something a licensed dealer/shop MUST fix, warranty or not. If it were a warranty, then a person with a vehicle not within warranty, would not be able to have it fixed free of charge...thus... given that there is a service bulletin (which leads to a recall notice 99% of the time) it is not a warranty issue. But I am not here to argue, I would like to return to the topic of this thread with the whole tuning thing. Thank you fellas and have a great evening.
Old Oct 17, 2017 | 09:11 PM
DTTJGlide's Avatar
DTTJGlide
Yes it needs to be retuned, & the SE tuner is very limited in it's abilities, unless you go to a better tuner about all you will gain is a little more sound. Good luck with your warranty-no warranty issue, it's a different ballgame now.
jeremiahpreston
Milwaukee Eight (M8)
Oct 24, 2017 12:54 AM
Timberwolf2017
May 13, 2017 10:10 PM
jkasevich
Apr 27, 2017 05:37 PM
gb911
Jan 26, 2012 04:22 PM
Marsh
Exhaust System Topics
Jun 15, 2007 11:00 PM
