Carbon Buildup inside left pipe
Old Feb 3, 2018 | 07:58 AM
ottomatics's Avatar
ottomatics
Default Carbon Buildup inside left pipe
My FLHTK M8 has stage 1 done with a Dyno Tune at the dealer. The left exhaust has a fairly heavy carbon deposit inside the left muffler end cap.
I understand only about 25% of exhaust goes through the left side, so why does all the carbon take the low road? Anyone know?
Also, I noticed that the back of the bike gets dirty after even a short ride.
Old Feb 3, 2018 | 08:22 AM
Doshounds's Avatar
Doshounds
There is alot less pressure coming out of the left side. Also the left side has hard 90 degree bend causing it to be cooler than the right side. The increased heat burns up the soot on the right side and the increased pressure coming out clears the rest of it. So the right side will always be cleaner than the left. Only way to solve that issue is a good 2-1. Now the back getting dirty, only way to solve that is not to ride it. The best way to justify it getting dirty is to ride a lot of miles each outing and the miles to dirty ratio will go down. But I agree they get dirty after just a few miles. Enjoy the ride man.
Old Feb 3, 2018 | 08:46 AM
Retrop's Avatar
Retrop
Ride more & worry less!
Old Feb 3, 2018 | 05:21 PM
BigRed117's Avatar
BigRed117
Great answer and excellent post!
Old Feb 4, 2018 | 05:35 AM
G'day's Avatar
G'day
I believe condensation play a part in this. As exhaust pipes cool, moisture forms within the pipes and they pool on the left pipe because of the side stand forcing the bike to lean over on the left.
Old Feb 4, 2018 | 05:54 AM
Hoginedgewood's Avatar
Hoginedgewood
If it’s not using oil I wouldn’t worry.
Old Feb 4, 2018 | 06:24 AM
smitty901's Avatar
smitty901
The HD exhaust is a scavenger. It favors one side to increase torque works some what like a 2-1. But the design balances the best of both worlds. Nothing new. Less flow on the one side makes for a cooler exhaust. The system works well.
Likely your Tuner cranked the fuel ratio up a bit more than needed . May want to have him adjust that.
Old Feb 4, 2018 | 09:48 PM
badcooky's Avatar
badcooky
Pretty dam close to spot on man.
user 7964469
Welcome Area Only
20
Sep 18, 2018 11:17 PM
Wmitz
Jun 12, 2018 01:10 PM
cameron.m
May 12, 2018 01:32 PM
Korbenw7p3c
Mar 20, 2009 08:46 AM
txbanshee
Southwest
Mar 31, 2008 06:49 PM
