SEPST idle issue
Old Feb 25, 2018 | 11:00 PM
lh4x4's Avatar
lh4x4
My 17 RGS with H-D stage I parts and tuner Idled at 850 prior to install and 950 after install and stayed smooth as silk for over 10K so far.
Old Feb 25, 2018 | 11:24 PM
Benedehh's Avatar
Benedehh
6th Gear
Noted! Thanks bud!
Old Feb 26, 2018 | 12:19 AM
Peter Quinn's Avatar
Peter Quinn
Don't let the guys get to you,just persevere and you will find a solution.
Could be you activated the idle cooling mode which deactivates fuel supply to the rear cylinder.If it sounds lik a single cylinder 500cc motor but is normal on the slightest touch on the throttle? Hope it is that simple!
Old Feb 26, 2018 | 12:38 AM
Benedehh's Avatar
Benedehh
6th Gear
Thanks, Quinn!
I don’t believe I activated the idle cooling mode. I’m new to the game, I would usually just be reading everybody else’s post but I can’t seem to see a similar problem with a solution.
Somebody will come along with the answer! 😂
Thanks again!
Old Feb 26, 2018 | 12:41 AM
Benedehh's Avatar
Benedehh
6th Gear
Also, inside the SESPT program it stated the “Desired idle” was at 1250. Not sure if that would make a difference. I don’t believe I can change it as well, that was just under the “Toolbox” tool.
When idling she jumps from 1350-1450...
Old Feb 26, 2018 | 07:28 AM
Peter Quinn
Default Eitms
Easy enough to test.Start the bike and roll the throttle fully closed and hold it for 10 seconds to deactivate EITMS.Hope thats it?
Have done many exhaust changes and run with only headers and even no headers!They get really loud but the idle never seemed to change except once when I damaged an oxygen sensor!
Good luck
Old Feb 26, 2018 | 09:38 AM
Harttoo's Avatar
Harttoo
I think ,It's time to reload the basic stage1 map.Before any smart tuning.Do You still have code and rough idle?
Old Feb 26, 2018 | 01:54 PM
Benedehh's Avatar
Benedehh
6th Gear
Good luck
Thanks, I’ve gave this a go, and I’ll be taking her out for a spin to see how she acts.
Old Feb 26, 2018 | 01:56 PM
Benedehh's Avatar
Benedehh
6th Gear
I will have to do this if the EITMS idea fails me. I’ll get back to you.
stitches1970
Aug 4, 2017 07:49 AM
yzernie
The Dyno Room
Oct 6, 2016 06:17 PM
470004
Dec 31, 2015 12:49 PM
titleist07
Nov 12, 2015 09:18 AM
Bigphish
Aug 6, 2014 07:47 AM
