Revolution Performance
Old Sep 26, 2018 | 05:20 AM
  #31
Mattbastard's Avatar
Mattbastard
Originally Posted by artsbest
There is a law pending in our House of Rep (Federal level) that would mandate ALL gas be sold at I believe it's 95 octane. The thinking there is the refineries will not charge the much higher prices after they get this gas up and running for all to use and it will also help in fuel mileage. Like I said it's on the books but will it ever come up for a vote is anyone's guess.
Why does higher octane alone give better gas mileage?
Old Sep 26, 2018 | 05:23 AM
  #32
Mattbastard
Originally Posted by Steve Cole
4.250 bore x 4/375 stroke gets you 124.129 cu in. You can bolt on 4.25 bore cylinders to a M8 stock engine case without boring the cases.
Yup, that math works, I just didn't think you could add a quarter inch of bore without case boring.
Old Sep 26, 2018 | 10:19 AM
  #33
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Higher octane does NOT assure better gas mileage. It's a very old wise tail, that some still believe.
Old Sep 26, 2018 | 12:26 PM
  #34
Oldskewl's Avatar
Oldskewl
And here I thought the term was " Old Wives Tail" because ex wives lie. See, I learn something new everyday.
Thank you!
Old Sep 26, 2018 | 01:04 PM
  #35
wallyj's Avatar
wallyj
Default High octane
Not a wives tale. High octane allows running higher compression which does produced better mileage.
Old Sep 26, 2018 | 02:46 PM
  #36
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Sure if your building a new engine, but just adding higher octane to and engine that does not need it, typically will lower the fuel economy hence the Old wise tail. Since 87/89/91 has been the fuel standards in the USA for going on 10 + years now, the engines are designed to run on those octanes. Building a new engine to run on say 93 octane or 95 octane is completely different. Putting in higher octane fuel than what is needed typically only lowers the level of dollar bills in your wallet.
Old Sep 26, 2018 | 07:25 PM
  #37
artsbest's Avatar
artsbest
but just adding higher octane to and engine that does not need it, typically will lower the fuel economy... Somebody better apprise our US House of Representatives of this.
Old Sep 26, 2018 | 08:46 PM
  #38
FatBob2018's Avatar
FatBob2018
You mean the group that decided it would be a great idea to force ethanol in our gas?
Old Sep 26, 2018 | 08:58 PM
  #39
Mattbastard
I know, I wanted to know if the person claiming that knew.
Yes, raising CR allows higher octane with the result of better engine efficiency, but notice I said "alone". Raising octane results in a slower, but more consistent burn. One that is not as susceptible to hot-spot preignition.
Old Sep 26, 2018 | 09:41 PM
  #40
artsbest's Avatar
artsbest
If anyone is interested this is what the gasoline future may look like in the US.
https://www.detroitnews.com/story/bu...ards/33902227/
