Clutch push rod
Old May 2, 2019 | 11:33 AM
Hairy Larry's Avatar
Hairy Larry
Big Kahuna HDF Member
deleted
Old May 2, 2019 | 11:35 AM
Hairy Larry
Originally Posted by Porkwrice
Are you guys just using the fatter 3 piece clutch pushrod from a 2014, or something else?
Some are using a fat rod sold by Greg Williams. I see this is your first post, welcome to the forums from Texas.
Old May 2, 2019 | 12:31 PM
Porkwrice's Avatar
Porkwrice
Thanks to all, I just purchased a 2019 Electra Glide Standard 3 weeks ago and I have put 3000 miles on it and so far I have had about 34 ounces of tranny fluid transfer....sooooo, not too happy.....dealer says it’s normal.....I am not happy with that so I am looking for a way to fix this.....I have had lots of different Harley’s over the years and I have never had any problems with any of them, so this being a brand new bike I thought for sure this was going to be awesome......
Thanks for the welcome....Hope I can get this figured out
Mike
Old May 2, 2019 | 12:53 PM
$tonecold's Avatar
$tonecold
Mike
Well have your dealer look up TA 0022 and he'll find out that it is not normal. That's enough transfer that the MOCO should OK installing the vent in the primary. If that doesn't fix it I would then try the fat pushrod.
Old May 2, 2019 | 01:24 PM
Porkwrice's Avatar
Porkwrice
Thank you....is there a way to contact Greg other than on FaceBook?.....I don’t have FaceBook.
Old May 2, 2019 | 02:15 PM
Keithhu's Avatar
Keithhu
Originally Posted by porkwrice
thank you....is there a way to contact greg other than on facebook?.....i don’t have facebook.
(586) 935-7433
Old May 2, 2019 | 05:01 PM
plongson's Avatar
plongson
Is "Greg" the only one making the fat pushrod? Looks pretty simple...anyone with a lathe and a mill can rip one out.
What puzzles me the most is, if the theory is to install a larger diameter push rod to stem the flow of oil through a tighter passage way, WHY is there a flat milled in the rod?? Seems to defeat the entire concept.
Old May 2, 2019 | 05:08 PM
Porkwrice's Avatar
Porkwrice
I am pretty sure it is simple.....I am a welder/fabricator, but I don’t know anyone with a lathe, soooooo this is what I have to do. The real question that I have is why does this only happen to some bikes and not others?....same driveline....same pushrod....and it only happens to some???.....I don’t get it.
Old May 2, 2019 | 05:33 PM
IrishDave's Avatar
IrishDave
4th Gear
From what I've read, i thought it was an m8 touring issue
Old May 2, 2019 | 06:57 PM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
Any M8 with a hydraulically actuated clutch.
