Top end noise
Old Sep 22, 2019 | 11:21 PM
oleboy's Avatar
oleboy
What is that tapping noise?
Old Sep 23, 2019 | 04:22 AM
Keithhu's Avatar
Keithhu
Originally Posted by Keithhu
Well I hate to say it, but it sounds pretty typical to me. YouTube makes it difficult to hear perfectly, but Harley's have always had pretty noisy top ends.
One month after posting this, I purchased a 2020 FLTRK. Its a great bike, but I will say that the top end is very noisy. I only have 500 miles on it so far, but it has a warranty, my attitude is just ride and not let it get to me.
Old Sep 23, 2019 | 04:42 AM
skid_pimp's Avatar
skid_pimp
Originally Posted by Punjabi Rider
I'm on 3rd set of these crappy HD lifters worse was the SE premium crap lasted only few hundreds miles. Seems like noise on my 3rd set is coming back again after little over 4K miles Sturgis trip. Not sure what the hell is going on every time I start the bike it pisses me off.
And this is exactly why I had them instal S&S lifters and lifter blocks when they did my stage 2 upgrades. I have not had good lifters from Harley in probably 15 years.
Old Sep 23, 2019 | 08:50 AM
Ericson38's Avatar
Ericson38
Originally Posted by KrustyKush
Sorry for your troubles. Some noises are significant sign of a problem. Your noises were also accompanied by other symptoms: fouled plugs, low oil, etc. Most noises are merely noises without any other symptoms. As any engine wears, it will get noisier. Harleys are not unique in this. A Gold Wing engine with over 100k miles on it will be pretty clacky. The ones I've heard have been. I had an 03 Honda VTX that I and my son put almost 60k miles on before selling it. A friend bought a 2005 VTX with only 5k miles on it, and one day we went riding. I could really notice the difference in noise clatter between the older and newer engines.
I have had 3 Goldwings, a 1977 naked , 1983 naked, and 2000 six cylinder. The 2000 had hydraulic liters, the other two solid tappets. They don't clack. Water cooled, deep piston skirts, multiple smaller pistons with lower side loads. Don't know about VTXs. They all had about 150K miles when I parted with them to get my 1st Harley, my current ride.
That's not the point anyway. My 2011 50K mile RK police is quiet. I love driving around on it just to listen to it go through the gears. I run rocker lockouts, 10w-60 non syn. Needed new lifters and cam at 38K miles. So about 12K miles on my SE 255 cam and HD lifters.
I run injector-valve cleaner about 6 times a year, to keep the injectors clean and the intake valves clear for good air fuel entry and swirl. A partially clogged injector will cause, due to the closed loop Ox sensor, a longer pulse length to get the A/F ratio back into target range. This can go undetected. These engines are also very carbon buildup sensitive. Air cooled pistons the size of a Ford 427 with short skirts are set up a bit looser than a car to start with, and blowby is routed right back down the throat.
I think a lot of clicking on an otherwise healthy engine is carbon or fuel injector related, not related to piston slap or small end rod issues.
Old Sep 23, 2019 | 09:09 AM
Jackie Paper's Avatar
Jackie Paper
Sounds normal to me for a air cooled motor with steel on steel (roller) bearings . That is not lifters. Get you a mechanics' stethoscope at harbor freight. Probe around with it in both ears. That will isolate exhaust. A problem would show up then as a tap. With the stethoscope, you will hear the steel on steel rollers as a steady whirr but not the tic.
JONNIEROCK
Sep 7, 2011 10:32 AM
97classic
EVO
Jul 14, 2009 02:17 PM
ajax1
Jun 1, 2009 04:52 AM
QT Hush
Exhaust System Topics
Jul 27, 2007 06:59 PM
mchaous
Aug 25, 2005 12:17 AM
