stock ventilator air breather
Old Nov 11, 2020 | 03:41 PM
harley7316's Avatar
harley7316
Default stock ventilator air breather
Hi was wondering,This is a stock Element part 29400267 says dry type element do not oil sentec.Can't seem to find info if this a reusable filter or not.Was wondering is someone knows?Thanks
Old Nov 11, 2020 | 03:46 PM
Quik's Avatar
Quik
That is the OEM ventilator filter, it is paper and does not require oil. HD says that filter is washable and reusable.
Old Nov 11, 2020 | 03:56 PM
harley7316's Avatar
harley7316
Thought is was but picked up a new take off and the guy was saying it not reusable and couldn't find any info
Old Nov 11, 2020 | 04:04 PM
golfblues's Avatar
golfblues
I have one and it is washable and oilable. Is that a word.....this is for the M8 version
Maintenance procedure from the installation instructions..
  1. Remove the air cleaner cover center screw.
  2. Tap the element to dislodge any loose dirt. Gently brush with a soft bristle brush.
  3. Spray air filter cleaner liberally onto the cotton filter media. Let soak for ten minutes OR roll and soak the cotton filter media in a shallow pan of air filter cleaner. Remove immediately, and let soak for ten minutes.
  4. Rinse off the filter media (flowing from the clean side to the dirty side), with low-pressure tap water.
  5. After rinsing, shake off all excess water, and let the filter media air dry. DO NOT use compressed air or a heat gun to speed drying.
  6. After the filter media is completely dry. EITHER spray air filter oil along each pleat, once only, holding the spray nozzle approximately 8 cm (3 in) away from the media, OR carefully use a squeeze bottle to deposit oil along each pleat, once only. Let the oil absorb into the filter media for 20 minutes before proceeding. After 20 minutes, inspect the filter media. Carefully apply oil to any remaining visible white spots on the filter media. Allow to absorb
Old Nov 11, 2020 | 04:09 PM
Quik's Avatar
Quik
That is for the ventilator high flow cotton filter (K+N) what he has is the OEM paper ventilator filter.
Old Nov 11, 2020 | 04:17 PM
harley7316's Avatar
harley7316
Yup says do not oil.I am sure paper won't last to many washing
Old Nov 11, 2020 | 04:27 PM
Quik's Avatar
Quik
Yeah I personally wouldn't wash and resuse it but maybe once, I would just purchase the high flow cotton element and be done with it.
Old Nov 11, 2020 | 06:10 PM
golfblues's Avatar
golfblues
oops, my bad....
Old Nov 11, 2020 | 06:56 PM
mikeo33y's Avatar
mikeo33y
i got my Ventilator off the wall at the dealership and it is an oiled element. I think the one that comes stock on the CVOs are not oiled
fastjoe
Mar 3, 2014 09:23 PM
MachU
Aug 15, 2013 07:50 AM
Mikekoz13
Sep 14, 2011 11:21 AM
Mikekoz13
Exhaust System Topics
Sep 14, 2011 07:50 AM
dwbcoyote
May 26, 2009 08:43 AM
