Thinking about a Compensator eliminator.
Old Jan 29, 2021 | 07:31 AM
dave the welder's Avatar
dave the welder
Default Thinking about a Compensator eliminator.
My bike has a stage 2, now I'm thinking about a Comp. eliminator. I thought I saw a brand that was 32 teeth instead of stock with is 34. Are they worth the effort? I saw one brand that has a manual adjuster, how often would one inspect?
Old Jan 29, 2021 | 05:31 PM
TTS Performance's Avatar
TTS Performance
Former Sponsor
Harley didn't fit the compensator on a whim. It protects the crank, starter, gearbox, clutch, drive belt from the nasty shock loads that this big V twin kicks out. Do away with it at your peril. If your making big power you can break the compensator ramps and that can do a lot of damage. I broke mine, so I made new ones out of EN36T hi-tensile steel. They don't break. PM me to find out more.
Old Jan 30, 2021 | 12:34 AM
NorthWestern's Avatar
NorthWestern
This is my fear. I am torn; I like the idea of the comp with my 128, but don't want pieces of ramp breaking of to get wedged below a sprocket...or do I ditch the thing and let the crank and trans soak up the load ?
I might like to hear more, sir!
Old Jan 30, 2021 | 01:31 AM
Bloody Marvelous's Avatar
Bloody Marvelous
An eliminator requires a lot of extra work. You'll need to upgrade your bearings, your complete clutch assembly. It'll make more noise, and not give you that much in gains unless you're taking it to the drag strip.
There is a middle ground though. Take a look at the Dark Horse Man-o-War motor sprocket. It's halfway between an eliminator and a compensator. It's got bushings that will still absorb a lot of the shock load, while being far more reliable and bulletproof than the stock comp. There is a 32T version, but unless you really need that extra gear ratio (which I don't think you do with a 128 build), I'd just stick with the 34T so your cruise control and gear indicators keep working like they should.
Old Jan 30, 2021 | 05:02 AM
dave the welder
Great responses, never thought about TTS performance wrote. Maybe I'll just leave things alone. Stage two really is all I can use on the street. Thanks!
Old Jan 30, 2021 | 05:15 AM
Campy Roadie's Avatar
Campy Roadie
I put a Dark Horse MOW 32T compensator on my 2011 Road King (versus the stock 34T) and like it a lot. All I had to do was go into Power Vision and change the gear ratios to make everything work correctly.
Old Jan 31, 2021 | 04:22 PM
TTS Performance
Former Sponsor
Old Jan 31, 2021 | 04:42 PM
TriGeezer's Avatar
TriGeezer
An M8 with a Stage 2 will not tear up the stock compensator. If you’ve got a highly built stop light to stop light racer...maybe then maybe consider. It’s extremely rare for someone to grenade an M8 compensator.
Old Jan 31, 2021 | 05:02 PM
60Gunner's Avatar
60Gunner
I posted pics recently of a stock M8 with the compensator in pieces. Less than 5000 miles if I recall.
There's also people here with 124s running compensator eliminators with plenty of miles with no issues. In fact, I have have yet to find one instance of any adverse effects of running a solid sprocket. Can it happen? Sure. So can the compensator disintegrating.
Im sure the clunking of the worn compensator I had didn't do the bearing any good and I've seen snapped or scissored cranks WITH a compensator. It's a shitty crank and can happen with or without a compensator just like the bearing can go with or without it.
The DarkHorse 32 tooth is not really a compensator but more a cushioned sprocket. Not a bad idea but too new to really know how well it will hold up. I like the idea tho.
I went with the 30 tooth compensator eliminator from Evolution Industries in my 100/110 twincam 103B with no regrets. This spring I'll be 120+ torque. I don't exactly baby it but I don't dump the clutch at 6000rpm either.
I do plan on doing the crank but not because I'm running a solud sprocket. Because it's a weak link period.
Bottom line is common sense goes a long way in longetivity.
People said Harley put the grenade plate in sporties for a reason too. Just before they grenaded!
Not the first bad idea they've come up with. Probably not the last either.
Old Feb 7, 2021 | 01:42 PM
mikeo33y's Avatar
mikeo33y
im doing this in the spring. just looking for some videos on installing this. Its the way to go.
