Plastic Lifter cuff failures ?
Old Mar 28, 2021 | 03:13 PM
Brueford's Avatar
Brueford
Default Plastic Lifter cuff failures ?
Has anyone heard of the plastic Tappet lifter cuffs / guides in the M8 engines which Harley has made of plastic failing and twisting under stress ? This is a bomb just waiting to happen ! You would think the bean counters at Harley would of learned a lesson with all the ruined engines with the Twin Cams and the plastic guide shoe on the cam chain, I guess it saves them a couple of dollars . Really Harley, you have lifter rods pumping up and down and you use a piece of plastic to keep them stable and straight ! I guess I now have to go after market and buy new ones made from billet aluminium and install myself , this will be my last Harley .
Popular Reply
Mar 28, 2021, 07:39 PM
702's Avatar
702
Let me make this thread worth reading. Found this on the Colorado yesterday.
Old Mar 28, 2021 | 03:20 PM
NorthWestern's Avatar
NorthWestern
Just try and chill a bit before you change to the billet cuffs, you might break a bolt off in the case. True story.
Old Mar 28, 2021 | 03:26 PM
smitty901's Avatar
smitty901
He is right.
When removing the bolt heat it with a heat gun not a torch. Back it out a little turn it back in \then out a little back and forth all the way out . Many do keep the HD plastic in place and pull lifters out the bottom. never seen the plastic fail. But on mine the S&S steel went in came with the kit anyway.
Old Mar 28, 2021 | 03:28 PM
Brueford's Avatar
Brueford
I will heat the engine with a heat gun to loosen the locktite , better than a lifter rod blowing through the engine . What is Harley's malfunction ? Do I need to go to the BMW's or Asian bikes ?
Old Mar 28, 2021 | 03:30 PM
NorthWestern
But seriously, I don't think I have ever read or heard of an actual failure? There are a lot of these out there, now, and most of us changed to S&S billet just because we were in there, doing a cam.
I never lost sleep over it. It was one of the "cheaper" upgrades. I would not change them unless I had a reason to pull it apart.
Old Mar 28, 2021 | 03:35 PM
MTBIG G's Avatar
MTBIG G
A bomb? How can you conclude the factory lifter cuffs are a "bomb" without knowing if there is actually a problem?
To answer your question... No, I havent heard of any "bomb" issues related to the factory lifter cuffs. Have you?
Old Mar 28, 2021 | 03:37 PM
NorthWestern
You don't need to freak out. IIRC these are the same style as the ones used in millions of the GM LS engines. I and many thousands of others have built some hefty HP engines with these cuffs.
A "lifter rod" won't blow through the engine. If a roller lifter rotates, it takes out the camshaft. The pushrod just becomes extremely loose when a lifter or camshaft fails.
There may be some isolated failures out there on HDs, I will ask Steve Cole if he has seen such a thing.
@Steve Cole
Like I said, I changed mine, but it was small change compared to the rest of the kit, and I was already in there.
Old Mar 28, 2021 | 03:38 PM
OldMike's Avatar
OldMike
Promise?
Old Mar 28, 2021 | 03:40 PM
MTBIG G's Avatar
MTBIG G
Yes, get rid of your Harley immediately before it explodes!
WTF is a lifter rod???? Lol
NorthWestern
2nd bomb thread in as many days. BATFE is going to be all over us.
