Cold start lifter noise
Old Dec 9, 2022 | 10:11 PM
propflux01's Avatar
propflux01
Originally Posted by Lammy1000
I was a bit confused because:
The Wood Alpha lifters instructions spec 0.120 to 0.140" push rod extension.
The Fuel Moto EZ pushrods instructions spec 4 turns for Wood lifters. These pushrods are 24tpi or 0.042"per 1 turn. So 4 turns X .042" = 0.168". Is 0.168 getting too close to the max lifter travel which is ~0.200"?
no, not too close. Keep in mind when cold, at that setting, you have .040 of travel, as the engine warms and expands, that .160 reduces down quite a bit, as the engine “grows taller”. Most engines will “grow” upwards of .100 when at operating temp. On a hot day, some even more. Hence why you see those that adjust “deep” usually don’t have lifter noise issues, and also why FM adjusts them deeper.
Old Dec 14, 2022 | 01:19 PM
bigal51's Avatar
bigal51
Replace everything in the cam chest. OIL PUMP, cam plate, cam bearings, seals, lifters and push rods. I'm pretty sure I had less than $400 in all the parts. No noise after that.
upflying
Apr 27, 2022 05:50 PM
martin10
Sep 21, 2018 08:51 AM
leo.silvano
Milwaukee Eight (M8)
26
Sep 26, 2017 11:11 AM
clackavosticus
General Topics/Tech Tips
Feb 12, 2014 09:09 AM
Hog Yild
Jan 14, 2012 07:13 PM
