m8 head upgrade
Old Oct 14, 2023 | 09:18 PM
MCsoup15's Avatar
MCsoup15
3rd Gear
Default m8 head upgrade
I have a '23 RGS 114, currently in the process upgrading my bike. So far, I have upgraded to a WM8-22XD cam, SE cam plate and oil pump, HPI 62mm throttle body and intake manifold, FM 6.1 injectors, Thundermax ECU, SPC 2-1 exhaust, and I had the SE elite heavy breather but going to the HPI V2 (I didn't like how far the ram intake sticks out) engine work wise. My question is, I have done a good amount of research, and it seems like almost no body upgrades heads before going to a big bore kit/increasing displacement and I don't understand why. Even a stock head that can get ported and polished would increase flow and in theory would then increase your power. More air, more fuel, more power. Anyone have any insight into this? I am sure there is a point where more power means you are ultimately going to need to increase displacement, but I'm trying to get everything I can out of my 114.
Old Oct 14, 2023 | 09:25 PM
M Oclaf's Avatar
M Oclaf
Because a majority have no idea what they’re doing and are just doing cause it’s cool and the dyno sheet shows they can now beat a stock Harley.
Old Oct 14, 2023 | 09:48 PM
MCsoup15's Avatar
MCsoup15
3rd Gear
Understandable. I wasn't sure if it was because people just not being aware, or it's keeping up with the jones' or what. Or if it wasn't worth spending money on heads then upgrading later to a bigger displacement with again upgraded heads. I don't see myself upgrading to a bigger displacement any time soon so I'd like to get the most out of this current engine for as long as I can, and upgrading the heads seems essential to me. Thanks for the input.
Old Oct 14, 2023 | 09:51 PM
M Oclaf's Avatar
M Oclaf
A bit of sarcasm but you’re on the right track, i
am far from an expert but know enough that installation of a cam without at a minimum porting and polishing the heads is as they love to say around here, leaving HP on the table. I wouldn’t install a cam without matching the heads to the new flow as you know. Good luck in whatever you do decide.
Old Oct 14, 2023 | 10:02 PM
MCsoup15's Avatar
MCsoup15
3rd Gear
I am newer to the Harley engine building, but I went to school 13 years ago for automotive and have built plenty of engines since then, so I'm just using that information and knowledge towards this. I have already ordered all my parts, regardless it's what I'm going to do. I just thought it would have been more popular and I couldn't find much information on it unless it was pertaining to a bigger displacement build. But I appreciate it either way.
Old Oct 15, 2023 | 06:50 AM
CoolBreeze3646's Avatar
CoolBreeze3646
Perhaps @fuelmoto will chime in and provide information on the M8 head as they work with them all the time.
Old Oct 15, 2023 | 06:54 AM
MattLS6's Avatar
MattLS6
The stock heads have proven to support ~140hp. The heads aren’t a constraint on a 114. Big bore kit simply offers a much better bang for the buck.
Old Oct 15, 2023 | 06:57 AM
Since 1968's Avatar
Since 1968
The stock M8 heads flow substantially more than the twin cams. It may be that even with opening up the intake and exhaust plus a cam the heads are still not a limiting factor. Could be a negligible improvement until you start adding cubes.... Just an opinion.
Old Oct 15, 2023 | 07:04 AM
OldMike's Avatar
OldMike
A good running Stage II is easy to build and not expensive unless you buy not needed extras. A nice running Stage II also means you don't remove the heads, a lot of people here can do this at home. If you remove the heads, it's time to go big bore.
Old Oct 15, 2023 | 07:16 AM
rigidthumper's Avatar
rigidthumper
Probably because stock heads have been shown to support up to ~150 TQ & ~145 HP on big bore kits. Hard to justify "bang for the buck" on a 114, considering it adds $2k to the price of a stage 2 setup.
