Located in the norcal area. Sometimes find myself riding in 100F temps. Have been running 20W50 Amsoil I'm my M8. Been thinking about going dino oil to quiet top end. Say spectro, valvoline vr 1, or Lucas? Change at 2k or 2500? Thoughts?
If you try the Spectro 25/60 wt . Post a review after you run it for a week or two . And tell us if it worked on the sound problem.
I run the Spectro 25w60 in my 2015 Road King. I'm in the Northeast, where temps rarely go beyond the 90s and I really don't ride when it's below 45 - 50 degrees. Compared to the Mobil 1 V-Twin oil that I previously used, the valve train is significantly quieter. My oil change interval is around 4000 miles since I average about 8000 miles per season and I do a change at the midpoint and end of each season.
That's good to know that it quiets it for you. Looking to do the same I hope
Nothing better than Spectro 25-60 when it comes to noise.
__________________________________________________ ____ For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
