Oil Archive (no new posts) An archive of oil related questions and comments.
Oil Pump Bolt Broken
Old Jun 22, 2006 | 04:44 PM
birsling's Avatar
birsling
Default Oil Pump Bolt Broken
Never fails, as soon as I am almost done with something, it has to take a turn for the worse. My last step before putting my pipes back on, and I break off an oil pump mounting bolt.
I was installing a Kuryaken chrome oil pump cover, and it called for 100-120 "inch" lbs of torque on the bolt. The key word being inch, and not foot. I broke it off in the oil pump mount. Can this be removed without removing the oil pump? Hoping I can make this a quick fix, but somehow I don't see it. Any help would be great!
Old Jun 22, 2006 | 09:28 PM
tripl8's Avatar
tripl8
Default RE: Oil Pump Bolt Broken
Take the other 3 cover bolts out..then take a vise grips to the broken one...sometimes common sense outweighs a Torque Spec ..especially with Alu.
Old Jun 22, 2006 | 11:39 PM
Longtimegone's Avatar
Longtimegone
Here you go ... http://mactools.com/SearchResults.as...Text=extractor
Snap-On, Matco and others make extractors, too.
You don't want to use a cheapo extractor. You want to do it right the first time.
Old Jun 22, 2006 | 11:48 PM
tripl8's Avatar
tripl8
Why would you try to extract when you can gain access to the "stud" after removing oil pump cover ??
Old Jun 22, 2006 | 11:59 PM
Longtimegone
Overtorquing a bolt puts stress on the bolt at the point the threads make contact. 'birsling' can consider himself very lucky to have the bolt break only the head off. It is unlikely he has much of a 'stud' left, but if so, that's wonderful. Common sense would tell me that if I have something to grab onto I am going for the vise-grips.
Good luck!
Old Jun 23, 2006 | 12:03 AM
tripl8's Avatar
tripl8
Dude..he has a 3 inch stud left..you ever take an oil pump apart??
bentparts
EVO
Aug 2, 2018 08:14 PM
glidein wide
EVO
Feb 26, 2016 06:17 PM
imboden
Shovelhead
Oct 7, 2013 05:04 PM
PANHEADMCC
Panhead
13
Aug 22, 2008 11:59 AM
cane22
EVO
Nov 4, 2006 09:37 AM
