Powdercoat & Paint A place to discuss everything about powder coat and paint for your Harley.
Oops! Eek!
Old Nov 8, 2011 | 04:52 PM
Mark757's Avatar
Mark757
Default Oops! Eek!
I occasionally use a backpack that slides over the sissy bar and I just noticed it is affecting the paint. It has left a hazy white area on my fender(softail) and it doesn't wash off. tried a clay bar. still no luck. suggestions?
Old Nov 9, 2011 | 11:37 AM
JRK5892's Avatar
JRK5892
what kind of paint do you have? it is tough to see from your sig pic
Old Nov 9, 2011 | 07:06 PM
MCSarge's Avatar
MCSarge
Try a little Turtle Wax polishing compound on a damp cloth and rub lightly. Let dry wipe off and polish with a good wax. Mine looks like new.
Same thing happened to me on my Night Trains rear fender after tying a bed roll with a nylon cover over it onto the fender for a trip.
Old Nov 13, 2011 | 12:41 AM
PanHeadRich's Avatar
PanHeadRich
^ He's right ^ you just chaffed the clear coat a bit. It will rub out without too much effort.
Old Nov 15, 2011 | 08:09 AM
deb1's Avatar
deb1
Is the bike denim? It looks like the paint is flat-not shiny in your picture. If this is the case rubbing it out will not work like it would on shiny paint.
Old Nov 15, 2011 | 02:23 PM
mbierbac's Avatar
mbierbac
Start with the lightest polish you can find. If that does not take out the marks go heavier. If that still does not get the scuff marks out you can go with 1500- 2000 grit silicon carbide(wet N Dry) sand paper and work backwards from where you left off with the coarse to fine polish then swirk mark remover
Old Nov 17, 2011 | 08:57 PM
Mark757's Avatar
Mark757
Thanx guys. My paint is Black Pearl. I tried a Turtle Wax polishing compound I had laying around.I was thinking it might just be the clear coat also. It did help but did not take it all out. what should be my next attempt? How do I "go heavier" before going the sandpaper route?
Old Nov 18, 2011 | 06:45 AM
rwrunski's Avatar
rwrunski
rubbing compound is a little more coarse than polishing compound so use that then the polishing compound
Old Nov 18, 2011 | 10:18 AM
mbierbac's Avatar
mbierbac
you can get different grits of polish, fine, medium and heavy, but be carefull! we wouldn't want you to burn through. If toy are polishing by hand you shouldn't worry. Usually polishing by machine will result in a burn through with heavy polish. Go to your local autostore and ask for fine, sanding polish, put some elbow grease into it. For a medium polish you might want to an abrasive cleanser we used to use in the body shop called "COMET". the next step i to work backwards removing the heavier grit scratches with the finer compound until you can finish with the turtle wax detailing compound
Old Nov 20, 2011 | 07:52 PM
Mark757's Avatar
Mark757
nice. i'll try it. THANX guys!
TwoBlue02
Jun 14, 2013 08:40 PM
firefightermike
Jun 4, 2012 07:57 PM
MJHJEA
Dec 2, 2009 02:14 PM
Razorback Rob
Feb 14, 2009 04:00 PM
street2007bob
Jan 23, 2008 12:49 PM
