Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Engine swaps
Old Jun 29, 2019 | 08:53 PM
jeremyjp's Avatar
jeremyjp
2nd Gear
Default Engine swaps
I have 2006 FLHPI police road king with 88in engine . Looking to upgrade to bigger engine . I could either get the big boar kit and be at 95, or I could buy a used 103 ofc Ebay and just swap engines. Question is ..... will it be exact bolt pattern match , and will the wiring be the same too? If not , what else will be needed ?
Old Jul 3, 2019 | 07:46 PM
Max Headflow's Avatar
Max Headflow
You need to buy a 99 to 06 except 06 dyna or any year softail. Most factory 103s are 2011-up motors and won't fit.
Old Jul 8, 2019 | 05:20 AM
grbrown's Avatar
grbrown
Talking
Or buy an aftermarket engine! The TC96 engines and later will not marry up to the earlier TC88 transmission, but a big S&S will.....
Old Jul 8, 2019 | 06:43 AM
Screamin beagle's Avatar
Screamin beagle
Bore to 98" ,cams and headwork if you can afford it and a good tune. You'll run circles around a stock or stage one 103s all day with out all the headaches of trying to bolt up a different drive train.
Old Jul 8, 2019 | 03:14 PM
djl's Avatar
djl
If the OP wants a 103" that will bolt up, he should be looking for a 103" motor from an early CVO model but the Beagle's suggestion makes the most sense.
Old Jul 9, 2019 | 05:45 AM
Mattbastard's Avatar
Mattbastard
How early did they start the 103" CVO models? I thought the TC88 year CVO bikes were only 95"
Old Jul 9, 2019 | 06:44 AM
grbrown's Avatar
grbrown
Wink
2004 according to my search! Seems several new things were introduced that year, such as the rubber mount Sporties.
Old Jul 9, 2019 | 09:25 AM
djl's Avatar
djl
IIRC, 2003 introduced the first 103" motor in the CVO Road King. CVO Electra Glide in '04 and '05; '06 the Ultra Classic and '07 the Ultra Classic and Road King.
Old Jul 9, 2019 | 03:02 PM
Eastcoast Jim's Avatar
Eastcoast Jim
As suggested go to 95" or 98" It will be very easy to seriously spank a 103 with some work you can beat a 110
donmecca357
May 4, 2018 12:40 PM
Scanbike72
Jul 29, 2014 08:35 PM
Jim Anderson
Engine Mechanical Topics
May 15, 2014 07:35 AM
chopincopper
Sep 22, 2012 07:02 AM
1911NT
Jun 18, 2010 07:08 PM
