Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
stripped transmission drain plug
Old Jul 25, 2007 | 02:11 PM
03 Softail's Avatar
03 Softail
Default stripped transmission drain plug
Need some advice, my neighbor has a 04 Fatboy and the transmission drain plug will not torque to spec.
If you would torque plug to spec it would strip out completly.
At present the plug is in (used alot of loctite) and not leaking.
What would be the best way to repair this?, as I do not beleive this will last for long and for sure will not make another trans fluid change.
Thanks for your help
Dan
Old Jul 25, 2007 | 02:25 PM
Rodman813's Avatar
Rodman813
Default RE: stripped transmission drain plug
I'm not an expert but, I'd take it out and start over again with a new plug, and o-ring. You said it's in and not leaking, but for how long. Shouldnt take a chance it will leak on a trip.If it don't torque right, it ain't right!!!!I just changed my fluids and I bought 2 extra sets of plugs for each hole just in case. The parts guy thought I was an idiot for buying 2 spares, but for less than $3 each, I put in the new one, and clean up the old one w/ new o-ring. It's my peace of mind.
The plug is Al, so you won't hurt the metal female side if you get it out. (supposedly)
Also, I'd used a square headedwrench instead of a round-headed allen wrench. (It just didnt fit right)
Old Jul 25, 2007 | 02:30 PM
lschultz's Avatar
lschultz
If the threads are gone in the transmission you might try a helicoil. Or find a tap and run it thru there and try and clean the threads up and see what happens. If all else fails tap it to the next size up. And I ain't no expert either. Maybe some of them HD mechanics will see this and respond or go to a shop and get there advice.
Old Jul 25, 2007 | 03:26 PM
fastglass's Avatar
fastglass
Helicoil thread repair at your local auto parts store.Just get the appropriat size.
Old Jul 25, 2007 | 04:53 PM
rbabos's Avatar
rbabos
Helicoil is best repair. I'd recommend making a fitting for the dipstick and run low volume compressed air in the tranny while tapping for the helicoil. Keeps chips from jumping inside the gearbox.
Ron
Old Jul 25, 2007 | 05:15 PM
03 Softail's Avatar
03 Softail
Thanks everyone for the information.
Looks like I'll go with the Helicoil.
Dan
Old Jul 27, 2007 | 08:22 AM
03 Fatboy's Avatar
03 Fatboy
There are oversize drain plugs make by Oil-tite available at auto parts store. Your drain plug should be 1/2" 20 thread per inch, they have double oversize and single oversize which are self-tapping. Also they have Piggyback self-tapping plugs with a small drain plug in the center of the drain plug. I would used the piggyback type so you still can drain the fluid without removing the main plug.
The problem withusing heli coilsis that there isn't alot of material aroung the drain hole to drillout for installing heli coils. You wil likely need to drop the shocks to install a new plug to keep everything straight.
Old Jul 27, 2007 | 02:53 PM
Navychief's Avatar
Navychief
ORIGINAL: rbabos
Ron
Good idea but be careful, some compressors have tons of moisture in them and you don't want water drops in your tranny.
Old Jul 28, 2007 | 01:35 PM
03 Softail's Avatar
03 Softail
03 Fatboy
I like your idea with the oversize piggyback drain plug.
I'll look for one. You are also correct on dropping the one shock to get at the plug properly.
Thanks for the advice.
03 Softail
myvegas03
Sep 27, 2020 04:18 AM
Wishbone68
Jun 30, 2014 04:40 PM
Bowhunter61
Nov 26, 2012 09:45 AM
CGLTD
Sep 16, 2008 08:32 PM
rexLitch
Nov 27, 2006 11:41 AM
