Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Although you did say you don't see any change in rpms it sounds more like a lean surge.
There was an issue with the early 06 bikes with the injectors. There was a service bulletin and if you had a problem the dealer put in different injectors.
If adjusting the primary chain doesn't fix the problem it may be lean in the range you describe.
I have the 25* injectors and that's what it was tuned for. The engine isn't surging at all. The bike is just rocking beneath me as i slow down.
I pulled the cover off today and being my OCD self, I checked it a few times. I have a bike jack but I didn't put the bike on it. Instead, I checked it off of the kick stand. The last measurement I got was 9/16th of an inch cold. I pulled the plugs and put the bike in 5th gear and rolled the bike about 4-5 feet. Insuring that there wasn't tension on the chain, I checked it in a couple of spots. It seems the chain is actually tighter than I thought. I haven't made any adjustments yet. I figured it would be loose. Other than putting the bike in the jack, am I missing something?
The chain being to tight could cause a problem also, as it tightens up as it gets hot. Chain should have 3/8" to 5/8" hot. So at 9/16" cold, it could be a little snug when hot. Also, chains and sprockets wear when it is to tight. I generally leave mine on the loose side at very close to 7/8" cold.
