Starting problems
Can anyone explain the exact process of the solinoid....my guess is that the plunger gets pulled into the tube on the solinoid and that moves the starter motor shaft outwards to the flywheel, when does the starter motor fire up? after the shaft is pulled to the flywheel?
Very important and most often overlooked.......
Is the bushing in the primary free of defects and debris??????
Starter drive gear Must be able to move in and out, and also spin FREELY......
Is the locking tab bent correctly at the bolt retaining the starter drive gear??????
Been overlooked more times than I can think..... Made a few $$$$$ off of that repair..... 'bout 10 times....
I will add another piece to the puzzle, a local bike shop put my starter in, the day I picked up the bike the shop owner explained how my old starter was not large enough to turn my new 110" motor. He attempted to start the bike and the starter motor appeared to get stuck....it was just spinning at very high RPMs. The seat was off the bike so the shop owner simply disconnected the battery to make the start motor stop. He then hit the primary with a rubber mallet, he thought the motor shaft was stuck in the bearing. It seemed to work, I did not witness it again.
Late last week I tried to start the bike, the same thing happened to me, the starter motor spun freely for 45 seconds while I disconnected the battery. Since that episode I have tried to start the bike a couple of times, but it was shortly after that....that I now have nothing but a clicking relay. That starter cost me $350, and really it has only started the bike twice, I think I will be trailering my bike project back to the bike shop.
By the way, here is a pic of my project.
[IMG][/IMG]
