Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
high rpms when warmed up
Old Mar 31, 2011 | 09:46 AM
shoot7mm's Avatar
shoot7mm
Stage II
Exclamation high rpms when warmed up
I have a 05' 883xl and when i start it up it idles pretty smooth but when i take off and ride it runs at high rpm in 5th gear (like 3200 at 60mph) and then when i stop it idles around 1300 rpms i have adjusted the cluth cable and changed trans fluid... iam stuck can anyone help me out???
Old Mar 31, 2011 | 09:48 AM
Mike T's Avatar
Mike T
Sounds like a possible intake leak.
Old Mar 31, 2011 | 01:11 PM
shoot7mm's Avatar
shoot7mm
Stage II
where do i start to figure out where the leak is at???
Old Mar 31, 2011 | 01:14 PM
Mike T's Avatar
Mike T
With your bike running, spray wd-40 around the intake flanges from the left side. If the rpm's go up, you have a leak.
Old Apr 1, 2011 | 04:50 AM
stilup's Avatar
stilup
MY crank position sensor on my prior bike the XL1200C did that.
Popped it out and just cleaned it and it would inprove for a month or so then did it again, cleaned it again and it went away again.
wierd as it wasn't burnt out just acting wierd.
You could try cleaning yours and see if it improves.
Easy to clean or replace. I did get a code. Forgot what the code error number was but see if you have a code.
Old Apr 1, 2011 | 10:21 AM
chappy99's Avatar
chappy99
you know that sounds right for your bike,i don't think you have a problem
idle hot=1300
5 gear 60 miles a hour=3200 rpm
Old Apr 1, 2011 | 10:24 AM
Mike T's Avatar
Mike T
idle hot=1300
I believe hot idle should be 1,000 rpm + or - 50.
Old Apr 1, 2011 | 10:42 AM
chappy99's Avatar
chappy99
960 rpm is minium,they don,t pump oil below that, so 1050 to 1100 cold and 1300 when
the bike is hot sounds right.
aGoodRogering
General Topics/Tech Tips
May 8, 2018 01:13 PM
misfitJason
Jan 31, 2017 09:58 AM
mholl
Aug 7, 2014 12:41 PM
BONES206
Jul 26, 2008 05:50 PM
asuperheat
Aug 29, 2006 10:13 PM
