Added Custom Dynamics ProBeam Turn Signals
Old Oct 27, 2018 | 08:14 AM
houstonhdguy's Avatar
houstonhdguy
Default Added Custom Dynamics ProBeam Turn Signals
Decided I wanted a little better lighting for my turn signals. Ordered a set of Custom Dynamics ProBeam turn signals. Already knew CD produced quality products, so I didn’t do an exhaustive search (like I usually do).
As you know the install was quick and easy with plug and play swap. Happy with the results. Much more light in run mode and turn signal is significantly more noticeable.
I also ordered a set for the rear signals, but they aren’t in yet.
Old Oct 27, 2018 | 10:05 AM
SWFLGuy's Avatar
SWFLGuy
So it runs the regular light until you hit the turn signal and then it goes amber?
Old Oct 27, 2018 | 10:35 AM
houstonhdguy
Yes sir.
Full LED white till you hit turns and then it goes amber. Both are super bright. Smoked lens keeps the original look.
Old Oct 27, 2018 | 10:36 AM
houstonhdguy
You can see the running light is actually a brighter white light than the stock lights.
Old Oct 27, 2018 | 11:11 AM
68 XLCH's Avatar
68 XLCH
I have them as well, you can't have too much light, day or night.
Old Oct 27, 2018 | 11:22 AM
SWFLGuy's Avatar
SWFLGuy
I believe that I am going with a full CD front light exchange. Those look great.
Old Oct 27, 2018 | 11:27 AM
IdahoHacker's Avatar
IdahoHacker
Went front and rear. Rears stay red until you hit the turn signal, then amber, just like the fronts go from white to amber.
Best thing you can do for better visibility, particularly if you ride at night, and don't want to be out in the dark with the suicidally-shitty stock Harley rear lights.
Love my Custom Dynamics LED lighting!
Old Nov 3, 2018 | 10:46 PM
flashracer's Avatar
flashracer
Bummer they told me the CD front turn signals won’t work with my 2018 cvo limited. I was going to have them swapped from my 2017 limited.
Old Nov 4, 2018 | 05:52 AM
FLHTCUSE KENTUCKY's Avatar
FLHTCUSE KENTUCKY
Custom Dynamics products are one of the best on the market. Also, great customer service as well. I changed my front and rear blinkers to the probeams as well.
Old Nov 5, 2018 | 10:52 AM
Custom Dynamics's Avatar
Custom Dynamics
Former Sponsor
Hey flashracer, that is true, the signals for the 2017 Limited won't fit on the 2018 CVO Limited because the CVO turn signals use a JAE plug instead of an 1157 plug. However, we do manufacture our ProBEAM Dynamic Ringz with a JAE plug for your motorcycle.
https://www.customdynamics.com/amfin...--flhtkse--752
