SE 110' RUNNING TEMPS
Old Mar 29, 2008 | 12:16 AM
Doc 1's Avatar
Doc 1
Default SE 110' RUNNING TEMPS
Does anyone have recorded or documented engine temps at normal running conditions. I know these bikes run hotter than normal but I;d like to hear some others that will confirm this.
Thanks, Doc
Old Mar 29, 2008 | 12:56 AM
skyhook's Avatar
skyhook
Default RE: SE 110' RUNNING TEMPS
hey doc, what's happening?...since you tuned my rk I traded it for 08 fxdse2, ran it 100 miles, then switched to r&r stage 4 heads(on 96" bathtub cores), 10.7 comp, se257 cams, supertrapp, power commander...running through town at 60*F ambient, it's reached 330* at head and 220* at oil filter...I've seen guys post on cvoharley.com that stockers get to 390* at the rear head...if you've got one on your lift check ccp...they're 215# with the comp releases turned off!
edit: now I'm not sure what the temp at oil filter was...it may have been less
Old Mar 29, 2008 | 09:41 AM
Doc 1's Avatar
Doc 1
Thanks Skyhook, Yes I seen where you got another bike....I've been keeping tabs on you.
The temp I'm getting is up to 277 from the ECM and 345 from the infrared temp gun. It is a trike conversion and the extra weight don't help I'm sure.
Old Mar 29, 2008 | 12:44 PM
bikerbehaviorist's Avatar
bikerbehaviorist
Here in NorCal with low to mid 60's air temp, I am running around 230-240 oil temp on an 08 SERK. Oil gauge sender is in the sump.
Old Apr 3, 2008 | 10:56 AM
wamp's Avatar
wamp
I installed a HD oil cooler, maybe 2 degree differnce in temp. I raised the tank 2 inches and now it runs ten degrees colder than stock when riding, still heats up good when not moving.
Old Apr 3, 2008 | 08:26 PM
SteveO's Avatar
SteveO
My 08 UCSE3 runs, 220-230 oil temp with air temp in the 80's+. Have oil temp in the sump.
Running Amsoil motorcycle 20W50 in all three holes.
Steve
Old Apr 4, 2008 | 11:29 AM
atlasfields's Avatar
atlasfields
Stock HD Synth, 350 according to the tmax software (head temp.) Air temp 50 degrees or so.
Now running updated map, Redline oil and I installed a Jagg's as added insurance. Not a single reading that high since the change.
Old Apr 4, 2008 | 06:09 PM
bikerbehaviorist
Just did a 20 mile ride with some intown, short twisties and freway. Air temp low 60's oil sump temp 210, infared thermo front cyl. 220, rear 280. Stock 08 SERK except for in line enrichers.
GymChamp
Nov 16, 2022 06:18 PM
jammerx
2014-2024 Touring Models
13
Jul 13, 2015 05:30 AM
tripleb1911
Mar 11, 2015 09:29 PM
Brick0044
Mar 7, 2015 09:03 PM
TedMan
Jul 6, 2011 03:39 PM
