ThunderMax EFI Module w/AutoTune for SE 110
Old Mar 6, 2013 | 10:50 AM
shustring's Avatar
shustring
The bike is still under warranty so I need to keep that in mind too. I don't think I will be changing cams. Just the pipes and air filter.
Old Mar 9, 2013 | 11:27 AM
Uffda's Avatar
Uffda
If you are just doing pipes & air cleaner, consider a remap/tune. I'd not waste money on any tuner until you do a little more. Also, warranty is not worth crap on a motor, once it's broken in successfully, there's little that can go wrong with it. If it did, you'd probably only get 'parts only' and probably not the 'parts' you want to go back with anyway. I have a T-Max w/frequently tweaked autotoune. Still eats TTS & SEST bikes with more spent than I, so it works for me. JMHO
Old Mar 11, 2013 | 03:47 PM
shustring's Avatar
shustring
I was told at the dealer that there was no remap or tune for my bike (2011 CVO ST conv) and that they would have to put in the other tuner.
Old Mar 11, 2013 | 07:44 PM
icebite1's Avatar
icebite1
I currently have TMaxs on 5 of my bikes, each one works flawlessly.
Old Apr 14, 2013 | 01:30 PM
shustring's Avatar
shustring
Originally Posted by Deuce Bigelow
I had one on my '07 FXSTSSE...
don't waste your money on it.
I removed the ThunderMax and bought the TTS MasterTune, felt an improvement in power and throttle response immedately...
did the Vtune procedure and the bike felt way better than it ever did!
I removed it because the ThunderMax has an issue with "bliping" the throttle, it would intermittently pop throught the intake, sometimes stalling the bike... it's a limitation of the Alpha-N software that they use.
went back to the HD ECM and loaded the TTS base MAP into the factory computer and saw an immediate improvement..
Back to the stock ECM?
Old Apr 14, 2013 | 01:32 PM
shustring's Avatar
shustring
Default Bassani Road Rage pipes
Hasanyone used the Bassani Road rage short pipes?
Old Apr 24, 2013 | 06:59 PM
Boost's Avatar
Boost
Originally Posted by Boost
I have the thundermax ECM on my Night Train and Zippers Performance is testing their new ECM (for the 2011-12 FLSTSE2 CVO Softail Convertible) on my CVO. Its a great product.
Just to follow up. I have my Bike back from zippers with the completed production ECM for the CVO Softail Convertible. They installed it along with D&D exhaust. It runs flawlessly. Better throttle response and power throughout the RPM range. 2 time satisfied customer.
Old Apr 24, 2013 | 09:45 PM
doc ock's Avatar
doc ock
I have an 04 EG with Gen1 Thundermax. Looking to get auto tune, well worth the money.
Sarge1
Aug 27, 2018 04:57 PM
rakanghoth
Apr 14, 2012 11:39 PM
ThaGlyde
Feb 29, 2012 05:59 PM
fattboy
Feb 23, 2012 12:10 PM
