110 SERT
Old Jan 24, 2007 | 02:27 PM
miker's Avatar
miker
Stage IV
Default 110 SERT
What is the p/n for the SERT for the 110?
I have SE a/c and slip-on's but don't like'em. The bike seems a little on the lean side too.
Thanks
MR
Old Jan 24, 2007 | 06:12 PM
wmlafond's Avatar
wmlafond
Default RE: 110 SERT
Mike
Harley Davidson's "Screaming Eagle Race Tuner" is applicable to all Harley engines, not just the 110 cid. Call your Harley dealer and they can order you one (likely have one in stock). The P/N is 32107-01E. Make sure you get a "new" one, never before installed (as they will work with ONLY the original VIN programmed into the unit). Also make sure you get one designed for the newer oxgen sensors.They retail for $459.95 but manydealers will discount them.
My area HD dealer offered to install SERT and Dyno Tune the engine (before & after charted results)for a flat rate 2 hours labor ($60/ hr), with 10% off SERT and the exhaust system (V&H Big Radius 2 into 1). That labor cost included installing the exhaust system as well (pretty cheap labor I thought?). You should be able to get similar pricing this time of year.
wide glider
Jan 15, 2011 01:17 PM
Nick1
Sep 27, 2010 07:13 PM
badspringer
Screamin Eagle CVO Models
Jan 4, 2008 06:26 AM
cirhere2
Oct 14, 2007 12:58 PM
deuceroadster
Apr 7, 2007 12:19 PM
