Static Timing Dyna S
Old Oct 31, 2014 | 09:01 AM
Racepres's Avatar
Racepres
Originally Posted by Joe12RK
When was the change from early to late?
Variable it seems...Some say at 80inches...some say 1980...two different deals!
I generally don't trust the Vin# for that kind of information...especially on equipment that is this Old..and known to have been Dealer rebuilt sometimes on the Showroom floor!!!
I always roll the motor over...And Look...Hell once I found an S&S flywheel I didn't know was in there!!!!!
Old Oct 31, 2014 | 05:11 PM
johnjzjz's Avatar
johnjzjz
you can check it yourself easy - take the timing plug out - lift the rear wheel so you can turn it counterclockwise - take the sparkplugs out - use a small 5 inch screwdriver put it into the Front plug hole and turn the motor over till the screwdriver is at full mast - look in the timing plug hole and see whats in it the vertical line or the dot
vertical line is late shovel wheels 1978 they changed the motor BUT giving to true harley they used up old stock haphazardly so an exact date cant happen
and the dot being TDC is early wheels and favoring the back of the hole it actually TDC not the center
Ston
Shovelhead
Jun 7, 2017 06:32 AM
Jonk777
EVO
Jan 18, 2016 06:15 AM
johnnyholmes
EVO
17
Aug 1, 2010 07:29 AM
supr2nr
Ironhead
May 5, 2008 08:47 AM
chuckles1856
May 16, 2006 02:59 PM
