Picked up my 77 FXE
Old Aug 28, 2017 | 02:04 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by flhchaz
VERY NICE! Sounds healthy.
Originally Posted by Architect
Congrats, and again I say
Sooooo shiny!!!!!!!!!!!!!!!!!!
Thanx guys. Looks like it'll be going to Rhinebeck next year.....
Old Aug 28, 2017 | 07:13 PM
TwiZted Biker's Avatar
TwiZted Biker
That bikes going to be crowd catcher
Old Aug 28, 2017 | 08:06 PM
98hotrodfatboy
I think it's going to be more than eye candy, but thanx..... I had it out on the expressway tonight and decided to open him up a little and wow. I would match this against my old Woods 6, 10.2:1 stage II heads, Evo build. This bike has a lot of torque... It was nothing to get it to 110mph.... sure the rpm's were up there but without a tach i'm not sure how hi.... I can't believe the power in this one.... I never thought a 74"er could get there..... I am very impressed.... I'm going to need to check the stroke on this one, I can't believe it's a 74"er....
Old Aug 29, 2017 | 05:53 AM
Architect's Avatar
Architect
i think it's going to be more than eye candy, but thanx..... I had it out on the expressway tonight and decided to open him up a little and wow. I would match this against my old woods 6, 10.2:1 stage ii heads, evo build. This bike has a lot of torque... It was nothing to get it to 110mph.... Sure the rpm's were up there but without a tach i'm not sure how hi.... I can't believe the power in this one.... I never thought a 74"er could get there..... I am very impressed.... I'm going to need to check the stroke on this one, i can't believe it's a 74"er....
leave the motor alone and enjoy the bike!!!!!!
Old Aug 29, 2017 | 07:04 AM
98hotrodfatboy
I plan on it... Just wanted to see what it had.....
On another note much to my surprise I couldn't believe I found both ears busted off the starter shaft housing on the starter. It's just floating around... Even the starter relay mount is broken so I lost my ground and had problems trying to start it last night.
Old Aug 30, 2017 | 07:28 PM
glidein wide's Avatar
glidein wide
Looks and sounds great Bob !!! Good luck with him/her...welcome to the four speed world bud !!!
Old Aug 30, 2017 | 09:21 PM
98hotrodfatboy
Thanx Kevin... I'm really digging him..... To bad the starter housing broke on it... Ordered one today along with a new relay... I'll be back on the road next week....
Old Jun 23, 2018 | 10:39 PM
Jim Widel's Avatar
Jim Widel
Stage I
Default 1981fxwg
My 1981 FXWG, Manley valves bronze nickel guides wiseco 9:5 to 1 forged pistons double plugged heads aluminum push rods dyna 2000i single/ dual fire ignition Andrews A grind solid lift cam Weber 40mm DCOE side draft 2bbl carbureator with primo Rivera intake manifold. 20 over 80 cu in motor and a supertrap 2 into 1 tuneable exhaust. Karats 1-1/2” primary belt drive with Barnett’s plates and springs and mucho mucho chrome all stainless lined rvrtybbehrrr˙fp
Old Jun 23, 2018 | 11:00 PM
johnjzjz's Avatar
johnjzjz
the Andrews cam has a very short duration for that compression my guess it ( Might ) be detonating I would put the timing back or maybe you have done that
nice package BTW
Haji
Shovelhead
17
Apr 29, 2018 08:16 AM
Rtlang
Shovelhead
17
Aug 7, 2014 05:37 PM
Lardog666
Jul 5, 2010 12:48 PM
eno50
Jan 17, 2010 10:05 AM
Low_Wider
Jan 21, 2009 07:03 AM
