Have a 78 FXE motor in a 77 FLH frame and the PO said the motor was rebuilt to Police spec (no paperwork ) . Any way to tell from outside appearances or do I need to pull the heads ?
Didn't know if there might be some secret code but the motor is a FXE (9D) and the cylinders do have 10 fins . So what's inside remains a mystery for now .
if, rebuilt it could've been pushed to 80" (likely police spec was just cam, carb etc) but if I'm not mistaken in 1978 it would have been 74" from moco
didn't know if there might be some secret code but the motor is a fxe (9d) and the cylinders do have 10 fins . So what's inside remains a mystery for now .
JD 1917 to 1929 and VL 1930 to 1935 had actual police internal parts ( big valve heads and cams / carbs ) in the engines and special clutch discs nothing else I have ever seen - the F in the chassis letters was for foot shifted police with out it was a tank shift, as most were until the evo came along 1984, then it was all foot shift from then on no tank shift available from Harleys evo police parts book anyway
6E = FXEF-80; superglide with electric start, fat bob tanks, 80 cu in motor
H9 = 1979 and if you saying it may be H5 that's 1975, but they didn't make an 80 inch motor in 1975, so go with the H9
The 5 in parenthesize is because there looks to be a partial '5' just after the 9. Can't really see in the pic, but quite obvious in person. It must be a dent that just happened to land next to the 9, thank you.
