Front Wheel Drive FL speedo Cable
Old Feb 11, 2018 | 07:09 PM
Racepres's Avatar
Racepres
Originally Posted by Hoyt 1911A1
I just double checked the rotor side of my front wheel and there is no spacer there. What looks to be a spacer is the GMA caliper that has the axle going through it. This appears to be the caliper I have:
https://www.jpcycles.com/product/243...lear-annodized
And Stock... it would have been a Spacer!!!
Rules out the left side tho!!! Now yer ditching the Hubcap and using a FLT/FLHT speedo drive [right side and a bit Longer!!] I don Not think you can get where you are trying to go and keep the hubcap.... But...Maybe with some creativity!!!
Old Feb 11, 2018 | 07:58 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
So if I did try to attach one to the right side would I need a new wheel hub for the little drive tab to fit into?
Old Feb 11, 2018 | 08:16 PM
Racepres's Avatar
Racepres
As I recall, the Softail Springer uses a small milled notch right in the Hub!!
[Right side drive]
I suspect Judicious use of a Drill would accomplish the same... I will look at that a bit... But Not Tonite!! I'm havin a Cocktail... LOL
Klumsy
Jan 29, 2018 06:19 AM
jrsmith313
General Topics/Tech Tips
May 7, 2017 09:07 AM
Knuck213
Mar 29, 2013 06:16 PM
berndog
Shovelhead
Jul 3, 2012 12:56 PM
fogcity123
EVO
Nov 5, 2008 08:23 AM
