mechanical speedo drivers
Old Nov 5, 2008 | 01:38 AM
fogcity123's Avatar
fogcity123
Default mechanical speedo drivers
I've asked about sppedos in the past and I have one more question: On my bobbed '89 Softail, with after market front wheel (21 inch), I just discovered I have a mechanical speedo drive in place. If I wanted to get a speedometer hooked up to it, how would I find out the ratio speedo I need and in regards to the cord, how do I connect it to the drive unit? Do I need to remove the front tire to access it? Thanks
Old Nov 5, 2008 | 08:23 AM
sqdealgeorge's Avatar
sqdealgeorge
Ratio is usually 2240:60 for this year/model bike Drive units cost about $60.00 However if the front wheel is dual flanged the more expensive drive unit($80.00) might have to be used CCI shows it as p/n 26738
Dr.Hess's Avatar
Dr.Hess
Assuming you have the right drive unit for your wheel, just get a speedo with a ratio that matches the year/model that the drive/wheel size came from. You could also count revolutions of the wheel and the cable and do some math, but it would probably be no more accurate. To connect it, you just insert the cable end into the drive and screw the cable into the drive. The other end has a fitting like coax.
fredskie
Shovelhead
Jan 19, 2020 10:42 AM
cskarns
EVO
27
Apr 3, 2018 06:29 PM
jrsmith313
General Topics/Tech Tips
May 7, 2017 09:07 AM
clyde585
Shovelhead
Jul 24, 2012 06:40 PM
berndog
Shovelhead
Jul 3, 2012 12:56 PM
