Neutral Switch Location
Old Mar 28, 2018 | 05:25 PM
Rusty Axle's Avatar
Rusty Axle
Default Neutral Switch Location
Dumb question time...
I've looked through the parts manual for my '75 FXE and I can't find the neutral switch location. I'm sure it's on the tranny somewhere, but I can't see it on the bike and can't find anything to point me at it.
The neutral light doesn't come on sometimes, could be a connection or could be the switch. I can't check the connection at the switch, 'cause I can't find it.
Old Mar 28, 2018 | 06:24 PM
Racepres's Avatar
Racepres
I seem to recall you have a '79.. should be a Cowpie/DairyQueen/Rotary top Tranny
Look on the right side between the engine and trans,, just below the oil tank... Prolly be a trick as I think it will be behind the rear Pipe, and Under the Darn Oil Lines!!!
Edit; DagNabbit wrong on me... You gots that '75? it should be a Ratchet top.. look on the other side [left side] just below the clutch cable adjuster...
Note; Those senders [Oil and Neutral] place a Ground on the line to lite the indicator.
Grounding the lead will tell you if the source of your problem lay in the Wiring...
Old Mar 28, 2018 | 08:31 PM
Joe12RK's Avatar
Joe12RK
look here:
neutral switch
Old Mar 28, 2018 | 08:38 PM
14GuineaPig's Avatar
14GuineaPig
Joe beat me to it
Old Mar 29, 2018 | 11:59 AM
Rusty Axle's Avatar
Rusty Axle
There it is - plain as the nose on my face...
Thanks guys!
Old Apr 1, 2018 | 07:34 AM
JAMES2's Avatar
JAMES2
I have one of those, it goes off ever time I start my bike while in gear.
Shakes and moves the whole damn bike, I hate it.
Old Apr 1, 2018 | 08:10 AM
johnjzjz's Avatar
johnjzjz
its the ground for the light but you can add the ground for your starter relay so that never happens to you again
GittinThere
Jul 10, 2019 02:50 AM
kc2002
Jul 13, 2018 09:43 AM
Crashone
EVO
Jul 8, 2018 08:18 PM
BACADon
Oct 30, 2015 04:47 PM
kyldh
Aug 21, 2013 10:06 PM
