Marking her spot
Old Jul 6, 2007 | 09:31 PM
manji99's Avatar
manji99
Default Marking her spot
I know it's not abnormal for a Harley to 'mark its spot' in the garage with a bit of oil, but how much is too much? I parked mine in the garage to work on it and the wife is spazzing out because it leaked maybe 1/2-1 ounce of oil on the plywood I put underneath it.
Kent
'79 Shovelhead FXE/FLH hybrid
[IMG]local://upfiles/33100/9E54CD1A03BD46ABBEC73D97DD32E692.jpg[/IMG]
Old Jul 7, 2007 | 05:01 AM
Gremlin's Avatar
Gremlin
Default RE: Marking her spot
Tell her it can only be fixed by pouring thousands and thousands of $$ in to it, and thatyour willing to sacrifice a little oil for her needs.
Old Jul 7, 2007 | 11:49 AM
panz4ever's Avatar
panz4ever
manji...that's about the size of a half-dollar. Clearly that is not abnormal for the older HD. I am assuming you are referring to your 79 shovel.
Old Jul 8, 2007 | 12:10 AM
str8pipe's Avatar
str8pipe
that sounds with in reason, i would not worry. i don't have a shovel but have a few mark on the garage floor from them.
Old Jul 11, 2007 | 10:17 PM
manji99's Avatar
manji99
ORIGINAL: Gremlin
Jeez, I hurt myself laughing at that one. I'll have to remember that line to use on her...
Kent
Old Jul 11, 2007 | 10:20 PM
manji99's Avatar
manji99
ORIGINAL: panz4ever
You are correct, I am talking about my '79 shovelhead. I talked to the guy that owns the shop where I bought the bike; he said to check the tightness of the bolts holding the outer & inner primary case together, also to check the setting on the drive chain oiler. I'm inclined to think that it is the drive chain oiler, as it pukes it out all at once when the motor is shut off.
Kent
'79 shovelhead FX/FLH hybrid
'78 Honda mini trail (the only Jap bike I have left)
Old Jul 12, 2007 | 01:10 PM
wbogley's Avatar
wbogley
Mine doesnt leak, however it does have the auto chain oiler. As I ride the chain throws oil on the back of the primary and frame. I then park, and I get a few drops where it drips off. No big deal. My buddy said the chain oiler will use 1 qt in 300 miles. (does 3 drops per minute when riding). Very normal.
Old Jul 12, 2007 | 07:28 PM
last shovel's Avatar
last shovel
you might also check the eng.vent hose (end) 60 secondsafter crankup or crankdown.Also,
the primary drain plug has a little lipped washer that easily gits misaligned, that plug very often is over tightened and so becomes semi-stripped. Also reccomend roses or slaps as anti-spazz measure.
lmz5150
Shovelhead
Apr 12, 2019 08:44 PM
63 Red Tail Hawk
Shovelhead
Aug 21, 2018 09:47 AM
roadapple1
Oil Archive (no new posts)
Aug 24, 2010 10:52 PM
stevodigitalfly
Flathead
Apr 25, 2008 02:35 AM
wadeiss
Feb 9, 2006 05:02 AM
