FLH wiring problems
Old Oct 16, 2020 | 08:47 AM
  #31
Racepres's Avatar
Racepres
Originally Posted by DrDirty
I loosened the clamp and there are rubber boots under the clamps that look a lot like the rubber bands. I will still check it for leaks but it looks OK for now.
Then those are Not the correct clamps that I see ... unless it is the angle of the pohoto or something... the clamps for Rubberbands should be Split.
Folks always have a hard time with using the Correct Stuff there...and then they dream up all kinds of "fixes" for the Problems they Cause..
Just a heads-up.. Yer gonna hear all kinds of crazy Fixes, and methods... when in fact... the Stock Setup works Just Fine.. Where Stock depends Entirely, on the Correct Components...
Originally Posted by johnjzjz
the brake light wire in the bars is a look at for orange shorting
The Most Likely in Fact!!!
Old Oct 16, 2020 | 09:50 AM
  #32
panz4ever's Avatar
panz4ever
So I can plug the orange power wire into any lug in block #3? I will try that tonight. I was wondering about last night after I had given up and hit the shower. It does sound like I could have a bad terminal block though, right?
If this is the case, am I looking on Ebay for one? My nearest dealer doesn't seem at all interested in looking for parts for my bike.
#72312-73. They have them on Ebay yes
Old Oct 16, 2020 | 01:33 PM
  #33
DrDirty's Avatar
DrDirty
I will check the front brake light switch this afternoon and if that is not the problem I am going to play around with the orange wire to see if acts differently when I plug it into another lug. I see them on V Twins for 50is so will get one ordered if I can't find another culprit.
Racepress, I will get better photos of the intake this weekend. I need to remove those big *** black zip ties that they had holding the fuel line. They would need to come off to remove the manifold anyway, and then I can get a better pic from the other side.
I will keep you all updated. Thank you so much for taking time to help me figure this out!
Old Oct 16, 2020 | 03:35 PM
  #34
edz1200's Avatar
edz1200
That looks like a good winter project. Can we see some pictures of the whole bike?
Continuity testing is important. To check the quality of the connection, the voltage drop test gives more information. Just connect a battery and voltmeter in line with the circuit you are checking.
Old Oct 16, 2020 | 05:21 PM
  #35
coax9952's Avatar
coax9952
I still believe you can count yourself lucky, when I acquired Victor, the PO had replaced his complete wiring harness with Black wire...… all of it...… and a cigarette lighter.
Old Oct 16, 2020 | 06:42 PM
  #36
old mago's Avatar
old mago
Black wires matter?
Old Oct 16, 2020 | 06:58 PM
  #37
johnjzjz's Avatar
johnjzjz
when ever in the ghetto i bring a black can of spray paint and any sign with lives - i add an O ( olives ) in the front of it
they then think an Irish guy wrote it
Old Oct 16, 2020 | 08:33 PM
  #38
DrDirty's Avatar
DrDirty
You guys are good. This was obviously the short.
Have power to the switches now but #1 and #2 on the termnal block are dead, no power at all. All the other blocks are hot.
The 4 way flasher is getting hot so I unplugged it, looks like I need that.
The directional flasher with the green wire has 12 v in but looks like only about 6v out. This doesn't seem right.
The front brake light switch was a crumbling mess, but I have power to it. Is this part of the switch or part of the mc?
I am making progress, just slowly. Started cleaning up some of the wires to the turn signals and passing lights, I can plug the wires to the turn signals into another block and get lights, so the wiring to them seems to be in tact.
I need another drink, this gets stressful. At least I will know a bit about the wiring on the thing when I am done.
Here is a better pic of the intake
I can't tell you guys how much I appreciate the help. This is an awesome group, glad I found it.
Old Oct 16, 2020 | 09:36 PM
  #39
coax9952's Avatar
coax9952
Originally Posted by old mago
Black wires matter?
Of Course, But only as a Ground Wire.......
Old Oct 17, 2020 | 09:28 AM
  #40
Racepres's Avatar
Racepres
That poor Front brake light switch has really had the weinie... The Green Weinie!!!
The threaded Body of the switch is still in there... Right hand Threaded...lefty Loosey..
How in theee hell did that switchhousing get so Corroded.??? was this bike a Flood Victim????
Someone Did Not know what they were doing, with that Intake
I would remove that at this Point. Heaven Knows what is under there... Betting a Rubberband Setup, but????
Those clamps are for O-ring
Humor me and see what is Under there... you are going to need to anyway..
