Well from your pics, in addition to what I have, I can see you need an FXE Battery Tray and Battery, Starter Relay, Gasket for the Solenoid, Gasket for the Primary to Starter Adapter, the Bracket (from the two Transmission Cover Bolts to the Battery Tray and Starter and the Rubber Stud Mounts; it is pictured on Tee Vee's parts) and of course you said you need a Ring Gear for your Clutch Basket or another Clutch Basket is probably easier to find. Then you will need to wire it up.
I can not see but on the top of your Primary, under the Oil Tank, can you see about a 5/8" diameter Slotted Screw Head? Is there at least about a 7/16" or so hole there? I don't have that pivot screw. Hopefully it or the hole is on top of your Primary.
Also in your Primary Cover do you have the Bearing for the end of the Bendix Shaft or at least the hole where the bearing goes? You will need that Bearing as well as a Copper or Brass??? Washer that rides on the end of the Bendix Shaft.
